If either of these are true....
This seems like it would be an easy one to do, but Im not getting it.
If any of the light switches in the master bath are on, and then any of them change to off, turn them all off..
Do I need to create variable when one goes on?  Im lost. Please help
Edited by phatmatt
There are probably opportunities to use scenes here, but below is a programmatic approach.  I made the assumption that there is no harm in turning off switches that were already off.
if
status switch1 is off
or status switch2 is off
or status switch3 is off
or....
then
turn off switch1
turn off switch2
turn off switch3
turn off....
if
or....
then
turn off switch1
turn off switch2
turn off switch3
turn off....
Thanks Oberkc.
I tried that before asking.  That program wont let the lights stay on.  If you turn on any of the lights, it turns it right back off.  I can say it, LOL, but I cant create it.
If any of the lights are on, and either of them changes to off, turn them all off.
1 hour ago, phatmatt said:
Thanks Oberkc.
Post your program
22 minutes ago, lilyoyo1 said:
Post your program
Master Bath Lights - [ID 001E][Parent 0001]
        'Master Bedroom / Bathroom / Matt's Sink' Status is Off
     Or 'Master Bedroom / Bathroom / Shelli's Sink' Status is Off
     Or 'Master Bedroom / Closet / Closet Switch' Status is Off
     Or 'Master Bedroom / Bathroom / Master Bath' Status is Off
        Set 'Master Bedroom / Bathroom / Matt's Sink' Off
        Set 'Master Bedroom / Bathroom / Shelli's Sink' Off
        Set 'Master Bedroom / Closet / Closet Switch' Off
        Set 'Master Bedroom / Bathroom / Master Bath' Off
This is why it doesn't work. You're looking at the status. If you only turn 1 light on and any of the rest are off, then the program will operate and turn off the lights
Change status to control and it'll work
If control a is switched off
Or b
Or c
Or d
Then set all of them off
Edited by lilyoyo1
Or b
Or c
Or d
Yep that was it.  TYVM
Sorry for the misdirection, @phatmatt.  Thanks to lilyoyo for getting it right.
You are also better off creating 1 scene with 4 responders.
That way you can turn that scene off, and they all go off in unison, instead of one at a time in rapid succession ('popcorn effect').
Funny you mentioned that. I noticed them going off one at a time, but hadnt looked into that yet.  Thanks.
