my 1st program..
Hello,  I am writing my 1st program,  but it doesn't trigger.  I can go into the main panel and turn the lamp mod on and off,  but nothing happens,  shouldn't my program turn if off after 2 seconds ?  thanks,  bill
No. Not if done from the panel. It'll turn off of you manually control the device.
When using control, only physical presses will trigger the program
Edited by lilyoyo1
This program will only run if the "401 Lamp" device sends an on command - usually triggered from a switch. What kind of device is "401 Lamp".
What you may want is status: If "401 Lamp" Status is On.
Edited by Goose66
What are you trying to do? Turn a lamp on wit a switch? Are they Insteon or zwave or a mix?
If Insteon you should create a scene. One of best features of Insteon.
thanks,  I got it running, program triggers form  main panel too.  It is an Insteon Lamp dimmer mod.  I changed it to status rather than control.   Will experiment a bit more.  thanks,  bill
There is a document called ISY Cookbook which explains how to do different programing and it has examples. Just search for ISY994 Cookbook. It will be very helpful.
