Standard "Query all" program causes an off/on
Hi all,
I've discovered that whenever the "Query all" program runs at 3 AM (a default program and time if I recall) , one of my on/off Outdoor Modules (2634-222) turns off and then turns on again. I can recreate this at will by running the Query.
What is this telling me and how do I fix it ?
Thank you, Peter
If you do not have a program running that is causing this (check the logs) then you might try a factory reset and restore on that device. I had an indoor on/off module doing the same thing a couple of years ago.
Dennis,
Thank you. I'll try resetting the module. It is not caused by a program, confirmed by both the log and the fact that I can trigger it by running the Query any time I choose.
Appreciated, Peter
