2420M adjusting light sensitivity
I can't seem to find where to adjust the 2420M settings through the ISY administrative console.. this one is marked 0909 REV 1.1 - is it possible the option isn't showing up because it's an older sensor?
Thanks in advance
Hi Robert,
What's your ISY's firmware version? You should be able to do that on firmware 2.7.6 and above:
1. Click on the Sensor node
2. In the main panel, click on the Set Options node
Thanks in advance
I'm on 2.7.6 but I thought it was supposed to be a right click on the motion sensor. I missed the options button at the bottom of the main pane. Thanks for the guidance.
