Two devices are finicky
I have a SWL and a KPL that are always problematic when I give voice commands.
The KPL rarely responds when I tell it to react in a scene (IE turn on upstairs 20%)
It'll do nothing until I say Hallway 20% ands usually after a few repetitions.
The SWL is pretty much the same.
This tends to get a little frustrating.
Any thoughts?
Drew
Just giving this topic a bump to see if anyone has any thoughts or solutions.
Drew
Drew,
If you are turning on/off a scene to which devices belong, then you have signal noise issue. The first thing I recommend is to move the PLM to a different outlet and one which is not shared with other transformers and power supplies. Otherwise:
1. Tips for troubleshooting signal/noise issues based our experiences: https://wiki.universal-devices.com/index.php?title=INSTEON:_Troubleshooting_Communications_Errors
2. The switches are bad
3. Contact SmartHome tech support https://www.insteon.com/support
