Keypadlinc KPL local and Load button in a scene
I have kpl v2c and ISY99 v2.7.0 wanted to make"a" button turn on and off a scene 4 switchlinc dimmers and the KPL's load .....is there a trick? or a thread read? I have seen all off threads? naturally everything works but the KPL's load will not turn on when using the "a" button on the local KPL.
then while I got someonse attention (this might be old) but if my (a,b c d) buttons are held in then they while dim /brighten the connected dimmers(except the local load)
thx mark
I am a nube but I am getting adjusted.
Hi Mark,
Two things:
1. If you have not already upgraded to 2.7.6, please do so (http://forum.universal-devices.com/viewtopic.php?t=3007 )
2. Within that scene, click on the A button, view the On Level for the load button and make sure it's not at 0. If it is, then change it to your desired level
thx mark
Thanks Micheal,
updating to 2.7.6 did it.
I had to restore the KPL and remove and remake the scene
