Zwave wireless switch issue
Just bought the Go Control 2 button wireless zwave switch in the the link below. I successfully added it to the ISY, but it shows up as "ZW032_1 - Uninitialized". I can't seem to do anything with it or use it to control any other devices. Any help on getting this to work is appreciated.
https://www.amazon.com/gp/product/B01BKWG9XS/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Firmware and UI? If you arent on the latest firmware, most likely it wont work. I would recommend using at least 5.0.16c  then trying. This is especially true if you are still on the 4.0 branch.
Firmware is at 4.8.0,My Zwave version is 4.55, UI is 4.7.3
You need to upgrade to 5.0.16c
Clear your Java cache before and after you upgrade
Got it. What is the benefit to upgrading my z-Wave board?
Not an easy question to answer.  But:
1) will allow you to upgrade past 5.0.16c when/if needed.
2) z wave backups are a lot faster on 500 board (not something that is needed often, but nice)
3) If you have all z wave plus devices it will give you advantages of zwave plus.
Thanks going to add the 500 card now and just get it done. One more question- with the latest version am I able to set the on-level of a zwave dimmer switch? This is something I always could do easily with Insteon switches, but do not see it as an option in the 5.0.16c for zwave dimmers. I've gotten around this with writing programs, but getting to be a pain with the # of devices I'm adding.
No. Unfortunately zwave devices all have different ways of accomplishing this unlike instrument.
You should be able to achieve this with a program. Let's assume you want the on-level to be 30 % :
IF
ZW XXX is switched ON (manually switched ON)
THEN
Set ZW XXX to 30 %
Edited by asbril
