Need help with Control and Status with Zooz Dimmer and 5.0.16C
Short story: I recently installed a Zooz Zen30 dual switch.  It has a dimmer on top and a relay below.  It's only partly working.  The relay reports its status when it is manually actuated.  The dimmer does not.  Both report status when controlled by the ISY, or when queried.
Neither will generate a "Control is switched On" (or off) trigger in programs.  As you might guess from the observation above, "Status is On" (or off) will trigger programs for the relay, but not for the dimmer.
Please give me your advice for getting the dimmer to report status, and for both to generate Control triggers - if it's possible.  Note: I'm on 5.0.16C with the 300 series dongle, so my Z-Wave menus will be somewhat different than yours if you are on 5.3.X.  Thanks.
-Tom
Thanks, but I'm in that post at the end.  @asbrilrecommended something, but it's only available in >5.2.  Unless I'm wrong, there's nothing in that post that describes how to fix the problems I'm having on 5.0.16C and series 300 dongle.  Did I miss something?
-Tom
-Tom
No. Your best bet is to upgrade your board since it's the newer firmware that supports what you need. I know it's not what you want to hear but it's really the only option
Edited by lilyoyo1
From this post:
Scene with only Zooz ZEN23 switches - ISY994 Z-Wave - Universal Devices Forum (universal-devices.com)
It looks like scenes and Control as a program trigger were reported as not working in 5.0.15, and I don't see anything in the release notes to suggest that this was fixed in 5.0.16.
I have ordered the 500 series dongle and will upgrade to 5.3.3 (or later) when it arrives.  Wish me luck on my Schlage lock when I do.
-Tom
