August WiFi Lock Support?
Had my old August locks in ISY previous to upgrading to the newer WiFi (No connect module required) locks.  Is there a way to get these added back to ISY and get some functionality out of them? Previously had it set up to allow for a singal from the car into a dry contact module that would trigger the locks to open.
  • 10 months later...
Just now, lilyoyo1 said:
If you have Polisy- there's a Node server for the august connect system
Any idea if that works with the Wifi locks or is it just the older Zwave locks?
No clue. I don't use August locks. Since it says August connect, I'd assume wifi.
There's a subforum for it if you look down the list on the main page under polyglot V3 node servers. You can post a question there for the developer
  • Thanks 1
