How to I integrate my Elk MI into UD Mobile?
SteveBL
I've been trying to integrate my Elk MI into the UD Mobile app but can't seem to do it?
Is it added as a NODE, and if so how is that done?
Posted (edited)
The Elk will show up using either the UD Elk Module (which is available for purchase on UD website) for the ISY or the currently in development Elk Nodeserver.
I should add that to use a Nodeserver you will need a Polisy or, for now, an RPI running Polyglot. When Polyglot 3 is released it is not expected to run on a RPI.
Edited by DennisC
Added info.
Well I do have the Elk Module and using EkeyPad Pro, it shows up just fine but I don't see it at all using UD Mobile yet I see all of my other devices.
I currently don't have a Polisy but it looks like that will change pretty quick here. ;)
Have you tried rebooting ISY and after it has completely started up, re-syncing UD Mobile? If that doesn't work, then I would suggest opening a help ticket with UD or tagging Javi.
Hi Guys,
Currently the Elk Module does not work with UD Mobile as the Elk Module does not have Node Server Files.  If the ELK Module is integrated into UD Mobile in the future it will be as a faux Node Server, much like UD Mobile implements programs, variables, and network resources.  Creating a faux Elk Node server is low on our list as, in my opinion, the Elk Node Server has greater functionality than the current Elk Module and already works with UD Mobile.
      37.3k
      373.6k
