Power Save Program
How would I code a program to cut the lights that are ON (or above 80%) to 80%? And call it from another program so I can determine what would trigger it - either a time, button push, etc.?
Hello brklass1,
Currently this feature requires a lot of programming since you would have to first know if the device is above some level and then apply the load shed signal.
We do have plans of supporting Power Save mode in the programs but, currently, it has a very low priority.
I have tried a few solutions - all do require much programming.
How do I check the value of a switch in an IF? Not checking for change, etc. Just current state?
Disable the program, and call it using Run (If).
       Status  'Dining Room' > 80%
       Set 'Dining Room' 80%
Rand
