replace device in 2.7.7 on ISY99 didn't update programs
Hi,
I just replaced a device via the replace function, but my programs did not get corrected.
I had to go through all programs and replace the with the correct device.
ISY-99I/IR Pro v2.7.7
Heiko
Michel,
thanks for the update.
What you can do is to use the Find/Replace function in the programs to look for Not Specified and then replace them with your new device.
Unfortunately this doesn't work either. If I select 'Raw Text', then there's no 'Replace with' available. There was no 'not specified' available when I chose the type 'Insteon'.
In addition to that, simply selecting the correct device didn't help either. As soon as I change it (manually) from 'not specified' to the correct device, the action (i.e. setting heat setpoint to 72) is lost (in this case it defaulted back to 'query') and I had to set everything again.
My ISY is already configured correctly again, but you may get a flood of complains once folks start replacing their thermostat adapter with the v2.0.
Heiko
Hi Heiko,
Thanks so very much. We will get right on it.
Michel,
Heiko
