KenUD2 Posted July 12, 2021 Posted July 12, 2021 The backlight keeps changing. I changed the backlight for the buttons to 15 ON 0 OFF. It works for a day or so and then changes to 0 On 0 Off. I have done this several times. Thoughts?
larryllix Posted July 12, 2021 Posted July 12, 2021 (edited) System communications disturbance noise. When a new signal gets sent, the noise confuses the binary patterns and the device get reprogrammed with nonsense. Do you have any other device commands that fail, or statuses that are shown incorrectly? KPLs are notorious for causing problems due to so many different devices inside one box. Make sure you have a Wait 1-2 seconds before changing LEDs On/Off scenes when another signal (PB) comes in. Edited July 12, 2021 by larryllix
gzahar Posted July 12, 2021 Posted July 12, 2021 5 hours ago, KenUD2 said: The backlight keeps changing. I changed the backlight for the buttons to 15 ON 0 OFF. It works for a day or so and then changes to 0 On 0 Off. I have done this several times. Thoughts? Are you actually seeing this behavior on the device or just seeing those settings in the admin console? The AC doesn't read these settings from the device and will normally display 0/0 unless you make a change and then continue to display that setting until you close and re-open the admin console in which case it will start displaying 0/0 again. This can make it seem like the device settings are changing when they are not. 2
