EZIO6I
evarsanyi
Hello mrp,
Thanks so very much for the detailed description.
First of all, the event viewer/INSTEON traffic are meant for users (or tech support team) who understand what the traffic really means.
With this said, the Process Response failed message is absolutely normal simply because your EZIO is responding with the same response twice (i.e. they are duplicates ... look at the SRX right before the failure). In short, the second response is considered duplicate, fails processing, and is ignored.
Now, with this said, I am quite surprised that you have gotten your EZIO to even send status updates (without query) to ISY.
So, may I summarize your post with the following:
ISY is not reporting the correct status of the EZIO inputs when queried?
I tried to make it clear I was an Insteon newbie. Apologies for mis-analyzing the duplicate messages. I've no clue as to why they would be happening.
Aye, "ISY is not reporting the correct status of the EZIO inputs when queried?" is my complaint.
I initially had problems with trying to link the EZIO6I to the ISY99i with the 2.6.x series. But, somewhere in 2.7.x, I merely entered the EZIO6I address, and may have selected EZIO6I in the device list (rather than letting it auto-discover), and things started working. Its been a while, and memory fails.
If it helps, here is the link table from my EZIO6I:
      • Figure 5. Link table from EZIO6I (01.70.F0). The PLM is 12.9D.12.
thanks for the reply!
cheers
Hello mrp,
Thanks so very much for the detailed analysis; it was quite helpful.
I can reproduce this problem intermittently and it has to do with the fact that we are getting two responses back from the EZIO ...
I just received an email from SHN outlining the new firmware for EZxxx devices which - I am very much hoping - is going to solve most (if not all) of our compatibility issues. I am going to send all our EZxxx devices back to SHN for the firmware to be updated (apparently, the first one to be updated is EZRain). Once we have the updated firmware, we'll delve deep into all the incompatibility issues.
Unfortunately - and without the updated SHN firmware - there's no easy fix that we can provide as it will be a temporary/patch work. I do understand your frustration and we'll do our best to get it out as quickly as possible.
  • 2 months later...
Hi Michel,
I am thinking of purchasing an EZIO6i. Have these issues been resolved? I did a search and this seems to be the latest thread talking about that device. If there are still problems with the EZIO, then I will just get separate I/O Lincs.
Thanks.
Randy,
You will need 2.8.0 to work with a new EZIO6I. I have tested 2.8.0 with a wide variety of new and old SHN EZIOxx products including the EZIO6I and found all working on 2.8.0.
Lee
  • 4 months later...
Greetings, have read this post with interest - I've been setting up an EZIO6I to interface with an alarm panel to give status on alarm arming, alarm triggered, smoke detectors triggerred, and a basement floor water alarm. I've updated my ISY-99i firmware to 2.8.8, and my EZIO6I was purchased in December 2008, and is running original firmware. I've linked the EZIO to the ISY with no problems, however, the ISY doesn't automatically detect a change in status without a "query" of the EZIO6I. So, in order to do my programming, I have set up an EZIO6I query loop, which queries the EZIO6I every 10 seconds.
My question - is this normal? Would an EZIO6I with updated firmware show it's status automatically as it changes on the ISY?
Any help anyone could provide out there would be much appreciated, thanks!
Schlyguy
NO, it is not normal. It should not be necessary to refresh the EZIO6I firmware. First question, was the EZIO6I added to the ISY under one of the 2.8.x images. This is a requirement. Next would be that the Link Management | Advanced Options | Automatic option is selected.
Lee
Lee
Thanks for your response. I've verified that Link Management / Advanced Options / Automatic Option is selected, and my ISY is up to date with V. 2.8.8. To be sure that the device was added under v. 2.8.8, I've removed my EZIO6I from my ISY, and unplugged the EZIO6I from its wall socket. Rebooted the ISY, waited 5 minutes, then plugged the EZIO6I back in, holding the SET button for 15 seconds to force it to reset. Then I re-linked the EZIO6I to my ISY manually using the EZIO's network address, and forcing it to remove existing links.
I've retested - and changes in status on the inputs do not appear on the ISY's device status, unless I query the EZIO first.
Any other help or hints you could provide would be appreciated!
Schlyguy
Schlyguy
That should have worked. I hate to do this but I need to see the command sequence and results when the EZIO6I is added to the ISY. Delete the EZIO6I from the ISY, start the Event Viewer with Device Communications events option set. Now add the EZIO6I using the New INSTEON Device, specifying Device Address, Name and selecting the EZIO6I from the Device Type pulldown.
The SHN devices ship with an internal PLM. As Smartlabs began updating the PLMs to support what was then the new 2000+ link record variant, the size of the memory used by the internal PLM changed. Starting with the 2.8.x images the ISY uses an algorithm suggested by Smartlabs to determine the size of the PLM memory which is necessary to know where to write the link records. This algorithm is complex and done once at the time the EZIO6I is added to the ISY.
Please post the Event Viewer trace. thanks
Lee
Lee,
As requested, same routine as before to remove / re-link EZIO6I, this time with event viewer / device communications.
Note - I toggled one of the inputs - 01.73.3E - A on at 12:25:20, and off at 12:27:20. Note that in the event viewer log - this input toggle does not show up at these times. Only when I "query" the device - do we see the change in state of 01.73.3E A appear - when queried at about 12:26:00 and 12:27:40.
Log follows:
Mon 12/20/2010 12:18:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:18:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:19:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:19:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:20:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:20:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:21:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:21:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:21:35 PM : ---- Initializing the linked devices ----
Mon 12/20/2010 12:21:35 PM : ---- All Linked Devices are now initialized ----
Mon 12/20/2010 12:21:35 PM : ---- Add remaining devices ----
Mon 12/20/2010 12:21:35 PM : [] Calculating EZxx Address Offset
Mon 12/20/2010 12:21:35 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:35 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:21:35 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:21:35 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:35 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:35 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:21:36 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:21:36 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:21:36 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:36 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:36 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:21:36 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:37 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:21:37 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:21:37 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:37 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:37 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 09 PEEK (09)
Mon 12/20/2010 12:21:37 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:38 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:21:38 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:21:38 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:38 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:38 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:21:39 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 01 06 POKE (01)
Mon 12/20/2010 12:21:39 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 01 POKE (01)
Mon 12/20/2010 12:21:39 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:39 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:39 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:21:39 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:21:40 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:40 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:21:40 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:40 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 02 06 POKE (02)
Mon 12/20/2010 12:21:40 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 02 POKE (02)
Mon 12/20/2010 12:21:40 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:41 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:21:41 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:21:41 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:41 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:41 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 09 PEEK (09)
Mon 12/20/2010 12:21:42 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 03 06 POKE (03)
Mon 12/20/2010 12:21:42 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 03 POKE (03)
Mon 12/20/2010 12:21:42 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:42 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:42 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:21:42 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:21:43 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:43 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 01 PEEK (01)
Mon 12/20/2010 12:21:43 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:43 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:43 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:21:43 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:21:44 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:44 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 02 PEEK (02)
Mon 12/20/2010 12:21:44 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:44 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:44 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:21:44 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:21:45 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:45 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 03 PEEK (03)
Mon 12/20/2010 12:21:45 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:45 PM : [] EZxx Address Offset at 3FFF
Mon 12/20/2010 12:21:45 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:45 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:21:45 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:21:46 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:46 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 01 PEEK (01)
Mon 12/20/2010 12:21:46 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:46 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:21:46 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:21:46 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:47 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:21:47 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:21:47 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:47 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:47 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 02 PEEK (02)
Mon 12/20/2010 12:21:48 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 FF 06 POKE (FF)
Mon 12/20/2010 12:21:48 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 FF POKE (FF)
Mon 12/20/2010 12:21:48 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:48 PM : [] EZxx start address at 0x0FFF
Mon 12/20/2010 12:21:48 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:21:48 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:21:49 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:21:49 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 03 PEEK (03)
Mon 12/20/2010 12:21:49 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:49 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 09 06 POKE (09)
Mon 12/20/2010 12:21:49 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 09 POKE (09)
Mon 12/20/2010 12:21:49 PM : [ 1 73 3E 1] Removing all links
Mon 12/20/2010 12:21:49 PM : [1 73 3E 1 ] Querying engine version
Mon 12/20/2010 12:21:50 PM : [iNST-ACK ] 02 62 01.73.3E 0F 0D 00 06 (00)
Mon 12/20/2010 12:21:50 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 0D 01 (01)
Mon 12/20/2010 12:21:50 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:21:50 PM : [1 73 3E 1 ] Retrieved engine version is i2
Mon 12/20/2010 12:21:50 PM : [1 73 3E 1 ] Calibrating engine version ensuring support for i2
Mon 12/20/2010 12:21:50 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:21:50 PM : [iNST-ACK ] 02 62 01.73.3E 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Mon 12/20/2010 12:21:51 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2F 00 (00)
Mon 12/20/2010 12:21:51 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:00 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:00 PM : [iNST-ACK ] 02 62 01.73.3E 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Mon 12/20/2010 12:22:00 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2F 00 (00)
Mon 12/20/2010 12:22:00 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:09 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:09 PM : [iNST-ACK ] 02 62 01.73.3E 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Mon 12/20/2010 12:22:10 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2F 00 (00)
Mon 12/20/2010 12:22:10 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:14 PM : [1 73 3E 1 ] i2 data transfer commands do not work. Reverting to i1
Mon 12/20/2010 12:22:14 PM : [1 73 3E 1 ] Using engine version i1
Mon 12/20/2010 12:22:14 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:14 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:14 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:14 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:14 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F8 06 PEEK (F8)
Mon 12/20/2010 12:22:15 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B E2 PEEK (E2)
Mon 12/20/2010 12:22:15 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:15 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:22:15 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:22:15 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:15 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:16 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:16 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:16 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F0 06 PEEK (F0)
Mon 12/20/2010 12:22:16 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 62 PEEK (62)
Mon 12/20/2010 12:22:16 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:22:17 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:22:17 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:17 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:17 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:17 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:17 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E8 06 PEEK (E8)
Mon 12/20/2010 12:22:18 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 62 PEEK (62)
Mon 12/20/2010 12:22:18 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:18 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:22:18 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:22:18 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:18 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:19 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:19 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:19 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E0 06 PEEK (E0)
Mon 12/20/2010 12:22:19 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 62 PEEK (62)
Mon 12/20/2010 12:22:19 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:22:20 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:22:20 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:20 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:20 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:20 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:20 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D8 06 PEEK (D8)
Mon 12/20/2010 12:22:21 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 62 PEEK (62)
Mon 12/20/2010 12:22:21 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:22:21 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:22:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:22:21 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:22:21 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:21 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:22 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:22 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:22 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D0 06 PEEK (D0)
Mon 12/20/2010 12:22:22 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 62 PEEK (62)
Mon 12/20/2010 12:22:22 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:22:23 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:22:23 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:23 PM : [] EZxx start address at 3FFF
Mon 12/20/2010 12:22:23 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:23 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:23 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B C8 06 PEEK (C8)
Mon 12/20/2010 12:22:24 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:22:24 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:24 PM : [ 1 73 3E 1] Adding device to ISY t=07.07.0000
Mon 12/20/2010 12:22:24 PM : [EZIO6I - 9] Start : Adding device to ISY
Mon 12/20/2010 12:22:24 PM : [EZIO6I - 9] Finish : Adding device to ISY was Successful
Mon 12/20/2010 12:22:24 PM : [EZIO6I - 9] Calculating EZxx Address Offset
Mon 12/20/2010 12:22:24 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:24 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:22:24 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:22:24 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:25 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:22:25 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:25 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:25 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:22:25 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:22:25 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:26 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:22:26 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:26 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:26 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:26 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:26 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:27 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 09 PEEK (09)
Mon 12/20/2010 12:22:27 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:27 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:27 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:22:27 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:22:27 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:28 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:22:28 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:28 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 01 06 POKE (01)
Mon 12/20/2010 12:22:28 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 01 POKE (01)
Mon 12/20/2010 12:22:28 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:28 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:22:29 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:22:29 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:29 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:29 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:22:29 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 02 06 POKE (02)
Mon 12/20/2010 12:22:30 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 02 POKE (02)
Mon 12/20/2010 12:22:30 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:30 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:30 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:30 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:30 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:31 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 09 PEEK (09)
Mon 12/20/2010 12:22:31 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:31 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 03 06 POKE (03)
Mon 12/20/2010 12:22:31 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 03 POKE (03)
Mon 12/20/2010 12:22:31 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:31 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:22:32 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:22:32 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:32 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:32 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 01 PEEK (01)
Mon 12/20/2010 12:22:32 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:32 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:22:33 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:22:33 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:33 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:33 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 02 PEEK (02)
Mon 12/20/2010 12:22:33 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:33 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:34 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:34 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:34 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:34 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 03 PEEK (03)
Mon 12/20/2010 12:22:34 PM : [EZIO6I - 9] EZxx Address Offset at 3FFF
Mon 12/20/2010 12:22:34 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:34 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 0F 06 SET-MSB(0F)
Mon 12/20/2010 12:22:35 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 0F SET-MSB(0F)
Mon 12/20/2010 12:22:35 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:35 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:35 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 01 PEEK (01)
Mon 12/20/2010 12:22:35 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 00 06 POKE (00)
Mon 12/20/2010 12:22:36 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 00 POKE (00)
Mon 12/20/2010 12:22:36 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:36 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:36 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 1F 06 SET-MSB(1F)
Mon 12/20/2010 12:22:36 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 1F SET-MSB(1F)
Mon 12/20/2010 12:22:36 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:37 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 02 PEEK (02)
Mon 12/20/2010 12:22:37 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:37 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 FF 06 POKE (FF)
Mon 12/20/2010 12:22:37 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 FF POKE (FF)
Mon 12/20/2010 12:22:37 PM : [EZIO6I - 9] EZxx start address at 0x0FFF
Mon 12/20/2010 12:22:37 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:38 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:38 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:38 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:38 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 03 PEEK (03)
Mon 12/20/2010 12:22:38 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 09 06 POKE (09)
Mon 12/20/2010 12:22:39 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 09 POKE (09)
Mon 12/20/2010 12:22:39 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:39 PM : [EZIO6I - 9] Calculating EZxx Address Offset
Mon 12/20/2010 12:22:39 PM : [iNST-ACK ] 02 62 01.73.3E 0F 4D 44 06 (44)
Mon 12/20/2010 12:22:39 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 4D 44 (44)
Mon 12/20/2010 12:22:39 PM : [1 73 3E 9 ] Link 0 : 0FF8 [E2090EDA77FF1F09] Saving [E2090EDA77FF1F09]
Mon 12/20/2010 12:22:39 PM : [iNST-ACK ] 02 62 01.73.3E 0F 4F 02 06 IOCTL (QUERY)
Mon 12/20/2010 12:22:40 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 4F 02 IOCTL (QUERY)
Mon 12/20/2010 12:22:40 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:40 PM : [iNST-ACK ] 02 62 01.73.3E 0F 49 00 06 RINPUT (00)
Mon 12/20/2010 12:22:40 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 49 00 RINPUT (00)
Mon 12/20/2010 12:22:40 PM : [ 1 73 3E 9] ST 0
Mon 12/20/2010 12:22:40 PM : [EZIO6I - A] Start : Adding device to ISY
Mon 12/20/2010 12:22:40 PM : [EZIO6I - A] Finish : Adding device to ISY was Successful
Mon 12/20/2010 12:22:40 PM : [EZIO6I - A] Calculating EZxx Address Offset
Mon 12/20/2010 12:22:40 PM : [1 73 3E A ] Link 1 : 0FF0 [E20A0EDA77FF1F0A] Saving [E20A0EDA77FF1F0A]
Mon 12/20/2010 12:22:40 PM : [EZIO6I - B] Start : Adding device to ISY
Mon 12/20/2010 12:22:40 PM : [EZIO6I - B] Finish : Adding device to ISY was Successful
Mon 12/20/2010 12:22:40 PM : [EZIO6I - B] Calculating EZxx Address Offset
Mon 12/20/2010 12:22:40 PM : [1 73 3E B ] Link 2 : 0FE8 [E20B0EDA77FF1F0B] Saving [E20B0EDA77FF1F0B]
Mon 12/20/2010 12:22:40 PM : [EZIO6I - C] Start : Adding device to ISY
Mon 12/20/2010 12:22:40 PM : [EZIO6I - C] Finish : Adding device to ISY was Successful
Mon 12/20/2010 12:22:40 PM : [EZIO6I - C] Calculating EZxx Address Offset
Mon 12/20/2010 12:22:40 PM : [1 73 3E C ] Link 3 : 0FE0 [E20C0EDA77FF1F0C] Saving [E20C0EDA77FF1F0C]
Mon 12/20/2010 12:22:40 PM : [EZIO6I - D] Start : Adding device to ISY
Mon 12/20/2010 12:22:40 PM : [EZIO6I - D] Finish : Adding device to ISY was Successful
Mon 12/20/2010 12:22:40 PM : [EZIO6I - D] Calculating EZxx Address Offset
Mon 12/20/2010 12:22:40 PM : [1 73 3E D ] Link 4 : 0FD8 [E20D0EDA77FF1F0D] Saving [E20D0EDA77FF1F0D]
Mon 12/20/2010 12:22:41 PM : [EZIO6I - E] Start : Adding device to ISY
Mon 12/20/2010 12:22:41 PM : [EZIO6I - E] Finish : Adding device to ISY was Successful
Mon 12/20/2010 12:22:41 PM : [EZIO6I - E] Calculating EZxx Address Offset
Mon 12/20/2010 12:22:41 PM : [1 73 3E E ] Link 5 : 0FD0 [E20E0EDA77FF1F0E] Saving [E20E0EDA77FF1F0E]
Mon 12/20/2010 12:22:41 PM : [ 1 73 3E 9] Device added to ISY
Mon 12/20/2010 12:22:42 PM : ---- All Remaining Device Added ----
Mon 12/20/2010 12:22:42 PM : [iNST-ACK ] 02 62 01.73.3E 0F 4F 02 06 IOCTL (QUERY)
Mon 12/20/2010 12:22:43 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 4F 02 IOCTL (QUERY)
Mon 12/20/2010 12:22:43 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:43 PM : [iNST-ACK ] 02 62 01.73.3E 0F 49 00 06 RINPUT (00)
Mon 12/20/2010 12:22:43 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 49 00 RINPUT (00)
Mon 12/20/2010 12:22:43 PM : [ 1 73 3E 9] ST 0
Mon 12/20/2010 12:22:43 PM : [ 1 73 3E A] ST 0
Mon 12/20/2010 12:22:43 PM : [ 1 73 3E B] ST 0
Mon 12/20/2010 12:22:43 PM : [ 1 73 3E C] ST 0
Mon 12/20/2010 12:22:43 PM : [ 1 73 3E D] ST 0
Mon 12/20/2010 12:22:43 PM : [ 1 73 3E E] ST 0
Mon 12/20/2010 12:22:43 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:22:43 PM : [1 73 3E 9 ] Link 0 : 0FF8 [E2090EDA77FF1F09] Writing [E2090EDA77FF1F09]
Mon 12/20/2010 12:22:43 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:43 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:43 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:44 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F8 06 PEEK (F8)
Mon 12/20/2010 12:22:44 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:22:44 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:44 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 E2 06 POKE (E2)
Mon 12/20/2010 12:22:44 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 E2 POKE (E2)
Mon 12/20/2010 12:22:45 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:45 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F9 06 PEEK (F9)
Mon 12/20/2010 12:22:45 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 09 PEEK (09)
Mon 12/20/2010 12:22:45 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:45 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:45 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:46 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FA 06 PEEK (FA)
Mon 12/20/2010 12:22:46 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:22:46 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:46 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:46 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:46 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:47 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FB 06 PEEK (FB)
Mon 12/20/2010 12:22:47 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B DA PEEK (DA)
Mon 12/20/2010 12:22:47 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:47 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:47 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:47 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:48 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FC 06 PEEK (FC)
Mon 12/20/2010 12:22:48 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 77 PEEK (77)
Mon 12/20/2010 12:22:48 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:48 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:48 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:48 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:49 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FD 06 PEEK (FD)
Mon 12/20/2010 12:22:49 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:22:49 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:49 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:49 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:49 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:50 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FE 06 PEEK (FE)
Mon 12/20/2010 12:22:50 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 1F PEEK (1F)
Mon 12/20/2010 12:22:50 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:50 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:50 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:50 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:51 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B FF 06 PEEK (FF)
Mon 12/20/2010 12:22:51 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 09 PEEK (09)
Mon 12/20/2010 12:22:51 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:51 PM : [MNG-LNK-RSP ] 02 6F 41 A2 09 01 73 3E 07 07 00 15
Mon 12/20/2010 12:22:51 PM : [PLM ] Group 9 : Writing Responder Link matching [1 73 3E 9 ] Link 0 : 0FF8 [E2090EDA77FF1F09]
Mon 12/20/2010 12:22:51 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:22:51 PM : [1 73 3E 9 ] Link 1 : 0FF0 [E20A0EDA77FF1F0A] Writing [E20A0EDA77FF1F0A]
Mon 12/20/2010 12:22:51 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:52 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:52 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:52 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:52 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F0 06 PEEK (F0)
Mon 12/20/2010 12:22:52 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:22:53 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 E2 06 POKE (E2)
Mon 12/20/2010 12:22:53 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 E2 POKE (E2)
Mon 12/20/2010 12:22:53 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:53 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:53 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F1 06 PEEK (F1)
Mon 12/20/2010 12:22:53 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0A PEEK (0A)
Mon 12/20/2010 12:22:54 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:54 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:54 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:54 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F2 06 PEEK (F2)
Mon 12/20/2010 12:22:54 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:22:54 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:55 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:55 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:55 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:55 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F3 06 PEEK (F3)
Mon 12/20/2010 12:22:55 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B DA PEEK (DA)
Mon 12/20/2010 12:22:55 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:56 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:56 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:56 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:56 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F4 06 PEEK (F4)
Mon 12/20/2010 12:22:56 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 77 PEEK (77)
Mon 12/20/2010 12:22:56 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:57 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:57 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:57 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:57 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F5 06 PEEK (F5)
Mon 12/20/2010 12:22:57 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:22:57 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:58 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:58 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:58 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:58 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F6 06 PEEK (F6)
Mon 12/20/2010 12:22:58 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 1F PEEK (1F)
Mon 12/20/2010 12:22:58 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:22:59 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:22:59 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:22:59 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:22:59 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B F7 06 PEEK (F7)
Mon 12/20/2010 12:22:59 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0A PEEK (0A)
Mon 12/20/2010 12:23:00 PM : [MNG-LNK-RSP ] 02 6F 41 A2 0A 01 73 3E 07 07 00 06
Mon 12/20/2010 12:23:00 PM : [PLM ] Group 10 : Writing Responder Link matching [1 73 3E 9 ] Link 1 : 0FF0 [E20A0EDA77FF1F0A]
Mon 12/20/2010 12:23:00 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:00 PM : [1 73 3E 9 ] Link 2 : 0FE8 [E20B0EDA77FF1F0B] Writing [E20B0EDA77FF1F0B]
Mon 12/20/2010 12:23:00 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:00 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:00 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:00 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:01 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E8 06 PEEK (E8)
Mon 12/20/2010 12:23:01 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:01 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:01 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 E2 06 POKE (E2)
Mon 12/20/2010 12:23:01 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 E2 POKE (E2)
Mon 12/20/2010 12:23:01 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:02 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E9 06 PEEK (E9)
Mon 12/20/2010 12:23:02 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0B PEEK (0B)
Mon 12/20/2010 12:23:02 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:02 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:02 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:02 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:03 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B EA 06 PEEK (EA)
Mon 12/20/2010 12:23:03 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:23:03 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:03 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:03 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:03 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:04 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B EB 06 PEEK (EB)
Mon 12/20/2010 12:23:04 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B DA PEEK (DA)
Mon 12/20/2010 12:23:04 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:04 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:04 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:04 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:05 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B EC 06 PEEK (EC)
Mon 12/20/2010 12:23:05 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 77 PEEK (77)
Mon 12/20/2010 12:23:05 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:05 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:05 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:05 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:06 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B ED 06 PEEK (ED)
Mon 12/20/2010 12:23:06 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:23:06 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:06 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:06 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:06 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:07 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B EE 06 PEEK (EE)
Mon 12/20/2010 12:23:07 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 1F PEEK (1F)
Mon 12/20/2010 12:23:07 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:07 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:07 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:07 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:08 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B EF 06 PEEK (EF)
Mon 12/20/2010 12:23:08 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0B PEEK (0B)
Mon 12/20/2010 12:23:08 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:08 PM : [MNG-LNK-RSP ] 02 6F 41 A2 0B 01 73 3E 07 07 00 06
Mon 12/20/2010 12:23:08 PM : [PLM ] Group 11 : Writing Responder Link matching [1 73 3E 9 ] Link 2 : 0FE8 [E20B0EDA77FF1F0B]
Mon 12/20/2010 12:23:08 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:08 PM : [1 73 3E 9 ] Link 3 : 0FE0 [E20C0EDA77FF1F0C] Writing [E20C0EDA77FF1F0C]
Mon 12/20/2010 12:23:08 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:09 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:09 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:09 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:09 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E0 06 PEEK (E0)
Mon 12/20/2010 12:23:09 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:10 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 E2 06 POKE (E2)
Mon 12/20/2010 12:23:10 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 E2 POKE (E2)
Mon 12/20/2010 12:23:10 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:10 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:10 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E1 06 PEEK (E1)
Mon 12/20/2010 12:23:10 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0C PEEK (0C)
Mon 12/20/2010 12:23:11 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:11 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:11 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:11 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E2 06 PEEK (E2)
Mon 12/20/2010 12:23:11 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:23:11 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:12 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:12 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:12 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:12 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E3 06 PEEK (E3)
Mon 12/20/2010 12:23:12 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B DA PEEK (DA)
Mon 12/20/2010 12:23:12 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:13 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:13 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:13 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:13 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E4 06 PEEK (E4)
Mon 12/20/2010 12:23:13 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 77 PEEK (77)
Mon 12/20/2010 12:23:13 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:14 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:14 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:14 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:14 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E5 06 PEEK (E5)
Mon 12/20/2010 12:23:14 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:23:14 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:15 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:15 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:15 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:15 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E6 06 PEEK (E6)
Mon 12/20/2010 12:23:15 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 1F PEEK (1F)
Mon 12/20/2010 12:23:15 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:16 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:16 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:16 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:16 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B E7 06 PEEK (E7)
Mon 12/20/2010 12:23:16 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0C PEEK (0C)
Mon 12/20/2010 12:23:17 PM : [MNG-LNK-RSP ] 02 6F 41 A2 0C 01 73 3E 07 07 00 06
Mon 12/20/2010 12:23:17 PM : [PLM ] Group 12 : Writing Responder Link matching [1 73 3E 9 ] Link 3 : 0FE0 [E20C0EDA77FF1F0C]
Mon 12/20/2010 12:23:17 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:17 PM : [1 73 3E 9 ] Link 4 : 0FD8 [E20D0EDA77FF1F0D] Writing [E20D0EDA77FF1F0D]
Mon 12/20/2010 12:23:17 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:17 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:17 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:17 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:18 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D8 06 PEEK (D8)
Mon 12/20/2010 12:23:18 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:18 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:18 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 E2 06 POKE (E2)
Mon 12/20/2010 12:23:18 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 E2 POKE (E2)
Mon 12/20/2010 12:23:18 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:19 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D9 06 PEEK (D9)
Mon 12/20/2010 12:23:19 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0D PEEK (0D)
Mon 12/20/2010 12:23:19 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:19 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:19 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:19 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:20 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B DA 06 PEEK (DA)
Mon 12/20/2010 12:23:20 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:23:20 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:20 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:20 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:20 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:21 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B DB 06 PEEK (DB)
Mon 12/20/2010 12:23:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:23:21 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B DA PEEK (DA)
Mon 12/20/2010 12:23:21 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:21 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:23:21 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:21 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:22 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B DC 06 PEEK (DC)
Mon 12/20/2010 12:23:22 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 77 PEEK (77)
Mon 12/20/2010 12:23:22 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:22 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:22 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:22 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:23 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B DD 06 PEEK (DD)
Mon 12/20/2010 12:23:23 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:23:23 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:23 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:23 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:23 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:24 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B DE 06 PEEK (DE)
Mon 12/20/2010 12:23:24 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 1F PEEK (1F)
Mon 12/20/2010 12:23:24 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:24 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:24 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:24 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:25 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B DF 06 PEEK (DF)
Mon 12/20/2010 12:23:25 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0D PEEK (0D)
Mon 12/20/2010 12:23:25 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:25 PM : [MNG-LNK-RSP ] 02 6F 41 A2 0D 01 73 3E 07 07 00 06
Mon 12/20/2010 12:23:25 PM : [PLM ] Group 13 : Writing Responder Link matching [1 73 3E 9 ] Link 4 : 0FD8 [E20D0EDA77FF1F0D]
Mon 12/20/2010 12:23:25 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:25 PM : [1 73 3E 9 ] Link 5 : 0FD0 [E20E0EDA77FF1F0E] Writing [E20E0EDA77FF1F0E]
Mon 12/20/2010 12:23:25 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:26 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:26 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:26 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:26 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D0 06 PEEK (D0)
Mon 12/20/2010 12:23:26 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:27 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 E2 06 POKE (E2)
Mon 12/20/2010 12:23:27 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 E2 POKE (E2)
Mon 12/20/2010 12:23:27 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:27 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:27 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D1 06 PEEK (D1)
Mon 12/20/2010 12:23:27 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:23:28 PM : [iNST-ACK ]
Log continues:
Mon 12/20/2010 12:23:28 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:28 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:28 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:28 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D2 06 PEEK (D2)
Mon 12/20/2010 12:23:28 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:23:28 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:29 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:29 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:29 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:29 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D3 06 PEEK (D3)
Mon 12/20/2010 12:23:29 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B DA PEEK (DA)
Mon 12/20/2010 12:23:29 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:30 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:30 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:30 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:30 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D4 06 PEEK (D4)
Mon 12/20/2010 12:23:30 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 77 PEEK (77)
Mon 12/20/2010 12:23:30 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:31 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:31 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:31 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:31 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D5 06 PEEK (D5)
Mon 12/20/2010 12:23:31 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B FF PEEK (FF)
Mon 12/20/2010 12:23:31 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:32 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:32 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:32 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:32 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D6 06 PEEK (D6)
Mon 12/20/2010 12:23:32 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 1F PEEK (1F)
Mon 12/20/2010 12:23:32 PM : [EZIO6I - 9] EZxx start address at 3FFF
Mon 12/20/2010 12:23:33 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 3F 06 SET-MSB(3F)
Mon 12/20/2010 12:23:33 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 3F SET-MSB(3F)
Mon 12/20/2010 12:23:33 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:33 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B D7 06 PEEK (D7)
Mon 12/20/2010 12:23:33 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 0E PEEK (0E)
Mon 12/20/2010 12:23:34 PM : [MNG-LNK-RSP ] 02 6F 41 A2 0E 01 73 3E 07 07 00 06
Mon 12/20/2010 12:23:34 PM : [PLM ] Group 14 : Writing Responder Link matching [1 73 3E 9 ] Link 5 : 0FD0 [E20E0EDA77FF1F0E]
Mon 12/20/2010 12:23:34 PM : [1 73 3E 9 ] Memory : Write dbAddr=0x0045 [0E]
Mon 12/20/2010 12:23:34 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:34 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 00 06 SET-MSB(00)
Mon 12/20/2010 12:23:34 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 00 SET-MSB(00)
Mon 12/20/2010 12:23:34 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:35 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B 45 06 PEEK (45)
Mon 12/20/2010 12:23:35 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:35 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:35 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 0E 06 POKE (0E)
Mon 12/20/2010 12:23:35 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 0E POKE (0E)
Mon 12/20/2010 12:23:35 PM : [1 73 3E 9 ] Memory : Write dbAddr=0x0044 [0D]
Mon 12/20/2010 12:23:35 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:36 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 00 06 SET-MSB(00)
Mon 12/20/2010 12:23:36 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 00 SET-MSB(00)
Mon 12/20/2010 12:23:36 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:36 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B 44 06 PEEK (44)
Mon 12/20/2010 12:23:36 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:37 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 0D 06 POKE (0D)
Mon 12/20/2010 12:23:37 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 0D POKE (0D)
Mon 12/20/2010 12:23:37 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:37 PM : [1 73 3E 9 ] Memory : Write dbAddr=0x0043 [0C]
Mon 12/20/2010 12:23:37 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:37 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 00 06 SET-MSB(00)
Mon 12/20/2010 12:23:37 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 00 SET-MSB(00)
Mon 12/20/2010 12:23:38 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B 43 06 PEEK (43)
Mon 12/20/2010 12:23:38 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:38 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:38 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 0C 06 POKE (0C)
Mon 12/20/2010 12:23:38 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 0C POKE (0C)
Mon 12/20/2010 12:23:38 PM : [1 73 3E 9 ] Memory : Write dbAddr=0x0042 [0B]
Mon 12/20/2010 12:23:38 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:39 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 00 06 SET-MSB(00)
Mon 12/20/2010 12:23:39 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 00 SET-MSB(00)
Mon 12/20/2010 12:23:39 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:39 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B 42 06 PEEK (42)
Mon 12/20/2010 12:23:39 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:40 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 0B 06 POKE (0B)
Mon 12/20/2010 12:23:40 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 0B POKE (0B)
Mon 12/20/2010 12:23:40 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:40 PM : [1 73 3E 9 ] Memory : Write dbAddr=0x0041 [0A]
Mon 12/20/2010 12:23:40 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:40 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 00 06 SET-MSB(00)
Mon 12/20/2010 12:23:40 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 00 SET-MSB(00)
Mon 12/20/2010 12:23:41 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B 41 06 PEEK (41)
Mon 12/20/2010 12:23:41 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:41 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:41 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 0A 06 POKE (0A)
Mon 12/20/2010 12:23:41 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 0A POKE (0A)
Mon 12/20/2010 12:23:41 PM : [1 73 3E 9 ] Memory : Write dbAddr=0x0040 [09]
Mon 12/20/2010 12:23:41 PM : [1 73 3E 9 ] Using engine version i1 for 'EZIO6I - 9'
Mon 12/20/2010 12:23:42 PM : [iNST-ACK ] 02 62 01.73.3E 0F 28 00 06 SET-MSB(00)
Mon 12/20/2010 12:23:42 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 28 00 SET-MSB(00)
Mon 12/20/2010 12:23:42 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:42 PM : [iNST-ACK ] 02 62 01.73.3E 0F 2B 40 06 PEEK (40)
Mon 12/20/2010 12:23:42 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 2B 00 PEEK (00)
Mon 12/20/2010 12:23:43 PM : [iNST-ACK ] 02 62 01.73.3E 0F 29 09 06 POKE (09)
Mon 12/20/2010 12:23:43 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 29 09 POKE (09)
Mon 12/20/2010 12:23:43 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:23:43 PM : [iNST-ACK ] 02 62 01.73.3E 0F 4F 01 06 IOCTL (01)
Mon 12/20/2010 12:23:43 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 4F 01 IOCTL (01)
Mon 12/20/2010 12:23:43 PM : [1 73 3E 9 ] Memory : EPROM Refreshed
Mon 12/20/2010 12:24:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:24:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:25:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:25:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:25:56 PM : [iNST-ACK ] 02 62 01.73.3E 0F 4F 02 06 IOCTL (QUERY)
Mon 12/20/2010 12:25:57 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 4F 02 IOCTL (QUERY)
Mon 12/20/2010 12:25:57 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:25:57 PM : [iNST-ACK ] 02 62 01.73.3E 0F 49 00 06 RINPUT (00)
Mon 12/20/2010 12:25:57 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 49 02 RINPUT (02)
Mon 12/20/2010 12:25:57 PM : [ 1 73 3E 9] ST 0
Mon 12/20/2010 12:25:57 PM : [ 1 73 3E A] ST 255
Mon 12/20/2010 12:26:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:26:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:27:21 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Mon 12/20/2010 12:27:21 PM : CLI-WBug: Successfully Processed WBug Response
Mon 12/20/2010 12:27:40 PM : [iNST-ACK ] 02 62 01.73.3E 0F 4F 02 06 IOCTL (QUERY)
Mon 12/20/2010 12:27:40 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 4F 02 IOCTL (QUERY)
Mon 12/20/2010 12:27:40 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:27:41 PM : [iNST-ACK ] 02 62 01.73.3E 0F 49 00 06 RINPUT (00)
Mon 12/20/2010 12:27:41 PM : [iNST-SRX ] 02 50 01.73.3E 0E.DA.77 2B 49 00 RINPUT (00)
Mon 12/20/2010 12:27:41 PM : [standard-Direct Ack][01.73.3E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 12/20/2010 12:27:41 PM : [ 1 73 3E 9] ST 0
Mon 12/20/2010 12:27:41 PM : [ 1 73 3E A] ST 0
Schlyguy
Thank you for the Event Viewer trace. It shows the ISY did what is expected for a PLM that is configured with the large memory to support 2000+ link records. However, the PLM firmware is operating as though the PLM has the small memory configuration. I do not understand how an EZIO6I purchased at the end of 2008 would have this PLM. Smartlabs did ship some of these PLMs as they were making the transition from small memory (417 link records) to large memory (2000+ link records) but the only time I have encountered one was a device purchased in 2007. The PLM firmware will have to be reflashed. SHN offers this service which will update the EZIO6I firmware and the PLM firmware to the latest level.
The Input status is not being updated in real time because the link records written by the ISY are not active as far as the EZIO6I internal PLM is concerned.
Lee
  • 4 weeks later...
Lee, I just got the EZIO6I back from SHN with firmware updated to v28 and PLM updated to v90. Input status updates now show in the ISY real-time without the query. Thanks for your assistance with the troubleshooting, much appreciated.
