Scheduled runs suddenly added to a program
Hi;
My ISY firmware is Insteon_UD994 v.4.9.0 (2020-12-22-11:51:19)
My User Interface is Insteon_UD994 v.4.7.3 (2018-07-09-16:44:35)
I have a program to turn on my outside lights (a scene) if it is after sunset and IFTTT detects I have entered a geo fence. IFTTT tells Mobilinc to do it. This has worked flawlessly for years. Suddenly, the program now runs twice per day at 6:35 AM and 6:54 PM. There are no schedule settings in the Program, Mobillinc, or IFTTT. I reset the ISY controller and wrote a new program, with the same results. I have attached a screen shot of the program.
Any suggestions would be appreciated.
Thanks in advance.
1) Your Firmware and UI versions need to match.  You're on a Mac so I'm not going to say you should be using the ISY Launcher as some Mac users seem to not have success.  But you must clear your java cache, delete any files you have named admin.jnlp and then use http://<IP.OF.YOUR.ISY>/admin.jnlp to save a new admin.jnlp.   when you're done and you launch the admin console both versions should be v4.9.0
2) the program you are showing us doesn't do what you have described.  it works entriely on time, at sunset +30 minutes a scene is being turned on and a notification is being sent.  At Sunrise minus 2 hours there is an attempt to send a notification, but the program says nothing about turning the scene off.  The Sunrise part won't work tho, because it needs to say "(Next Day)" on the sunrise line of the IF statement.
Also note this program has been changed/modified and is UNSAVED, which means it's not working.  A program must be Saved before it takes effect.   the green arrow on the program name is the clue.
3) the better way to post programs to the forum is to RIGHT CLICK the Program name and select Copy to Clipboard.  Then in your forum post use the "<>" symbol on the tool bar and paste your program into the window that opens when you press "<>"/
Edited by MrBill
Thank you, Mr. Bill. Clearing the java cache did the trick. I will use the ISY Launcher going forward.
