Occupancy Node Server
I have 5.1.1 running for ISY on my Polisy and started moving some devices over that don't tie into node servers or my Z-Wave devices and they are working fine. I tried setting up the occupancy geofence in the portal but I can not get anything added for Polisy. I was able to configure the node server connection and performed the node definitions upload but after the ISY services reboot it still shows nodes definitions not installed. When I try to add an occupancy geofence it says node server not configured. Has anyone ben able to get this working?
Tom
Tom
I've not been able to get that node server to work on Polisy. It's been awhile since I tried but as I recall, Polisy does not support the Bluetooth module the nodeserver relied on for that function.
I switched to using the ping node server to identify when my or my wife's phones are on my LAN. It has a few quirks but generally has worked well for me.
Reading my post again I see I was not clear on the fact that I'm talking about the occupancy node server that is available through the portal! @DaveStLou since my original ISY is still using the polyglot node servers I can't look into those node servers at this time. To be honest I do not need this working right now but I'm just trying to see if this is a bug since we are still in the early stage of testing with this.
Ahh. I was crossed up and thought you were talking about the Presence-Poly nodeserver.
