ISY with integrated PLM
The current ISY requires a serial PLM. In the next year could there be an updated ISY that works with the Insteon USB PLM or has an integrated X10 and Insteon PLM?
I currently use the Insteon hub 2242 to control a mostly X10 environment. I also use a PowerBook 1400 running XTension with an X10 ActiveHome serial PLM. Recently a switch failed I am deciding between getting an Insteon switch or a Leviton switch with Wi-Fi that works directly with Apple HomeKit, Leviton D26HD-2RW.
Can the ISY send commands to the Insteon hub 2242? I could then use it for an X10 door contact sensor to send a command to an Insteon controlled light switch.
