Polisy will not factory reset
Front end version and Version:2.2.9-5 & 2.2.13
ISY on polisy version 5.3
@Michel KohanimFinally got around to setting up my backup Polisy to try out the Insteon import abilities with the 2448A7 adapter. The experience was terrible to say the least. Everything imported just fine except none of the devices will talk to the ISY. They show as if connected but no status from any of the devices. Trying to restore does not work nor does writing updates to devices.
Polisy goes through the motion like its working but nothing comes of it. Unsure if it was the usb adapter or not (it shows the adapter being connected with the proper insteon id), I attempted to factory reset so I could try with a PLM.
Polisy does not factory reset. Doesnt even do the normal tunes that I get with my other Polisy. Ive held the button in for 3 minutes and only 2 of the lights blink. With the ISY finder open, it still shows polisy as connected (doesnt disappear the way the 994 does)
Edited by lilyoyo1
55 minutes ago, Michel Kohanim said:
@lilyoyo1,
What's the output of:
uname -a
pkg info udx
pkg info isy
Thanks Michel. I'll check that when I get back to the house
On 1/17/2022 at 1:57 PM, Michel Kohanim said:
@lilyoyo1,
uname -a
pkg info udx
pkg info isy
Sorry for the delay Michel, Here's the info.
uname -a: FreeBSD polisy 13.0-RELEASE-p6 FreeBSD 13.0-RELEASE-p6 #16 releng/13.0-n244774-b0c8bc5d9cd: Wed Jan 12 18:39:31 UTC 2022     ec2-user@bsdev.isy.io:/usr/obj/usr/src/amd64.amd64/sys/POLISY  amd64
pkg info udx: 2.5.3_27 Freedsb version 1300139
pkg info isy: 5.3.0_19
15 minutes ago, Michel Kohanim said:
@lilyoyo1,
Thank you. There was a bug with udx ... please do the following:
sudo pkg update && sudo pkg upgrade
sudo service udx restart
sudo service isy restart
Reload your backup.
Thanks for your help Michel. Looks like we have another snow storm coming Friday so I'll reload the backup then. I went ahead and ran all the commands though. Time to head back to Cali for the winter. Im over our weather after this week
1 hour ago, Michel Kohanim said:
@lilyoyo1,
I feel you ... I was in Philly last weekend. Quite a freezing experience ....
I refuse to go up north for that very reason. I can't even handle southern Winters
Winterly 54F this morning in Miami, but 74F now at 3 pm :-)
That's more like it. I just can't deal with your summers
