2.7.8/9 Instructions
This isn't technically a bug and perhaps you want it this way.
If you have a device in a folder and disable it then you can remove it from the folder in which case it will move to the root folder But you can't remove it from ISY when it's disabled. A disabled device cannot be removed - it must be enabled first. This may be by design.
I had a device which I removed from a folder and then was able to remove from the root folder. This made the device disappear from the entire left pane though it remained in the right pane 'my lighting' screen. I can't reproduce this behavior, though.
mark
  • 2 months later...
Does anyone know if there is an easier fix yet? I really don't want to start voiding my warrantee by soldering the internals of my thermostat.
