Z-Uno 10 Channel not fully configured
I was Experimenting with the Z-Uno and found it to to work perfectly with Raspberry Pi Home Assistant but when testing it to the ISY 944i I was a little short in their implementation . I was reading a 2018 thread that said it was fully implemented I must be missing something cause it only picks up one of each the defined element.
Am I missing something here?
if someone could point me in the right direction it would be appreciated.
300 or 500 board?
Firmware  AND UI of your ISY
I upgraded the Z wave module to the the 500  when I upgraded to the 5.x.x.firmware. Been running a polglot node for my raspberry to bring  information in but it presents it poorly in the ISY device and doesn't work with mobilink
Well no Joy,, Matter of fact I lost all my Z wave devices and it will not  let me install them. I think it might be time to can the ISY Products I had a isy-26 then upgraded to the 99i then the 994i been in this for 10+ years getting a little disappointed in the advancement.
With this statement, I assume you do not plan on ever buying another car, computer, phone, tv, house, etc? Everything in life gets upgraded at some point. 3 controllers in 10+ years is still less than a grand.
Ok  re-Formatted the sim car reinstalled the firmware and installed the configuration. It all seems to work to at least to where I was. The Z -Uno still is not reporting all the I/O thought it does with Home Assistant. Just for reference I had installed the new Zwave Card and had an old back up  I would not have been running Version 5.3.0 firmware if I had not replaced the card.  I am also aware of polglot being I have a node Running on a Raspberry Pi.  If you look at the statement that it is supported  in a previous thread on the forum.
