Cannot Log into polisy
@Michel Kohanim
I am unable to log into one of my polisy's. It shows up in the launcher but nothing happens when I click on it. SSH'd into it and ran the different  updates which there are none. Stopped and started UDX and ISY and its still a no go.
Also is it possible to sart all over with a clean slate as if this polisy had never been used? It was once connected to my isy but I dont want to port the system over (I want to do a fresh install).
uname -a=13.0 release P6 Free BSD 13.0 release p6 #16
pkg info udx= 2.5.3_36
pkg info isy=5.3.0_26
Edited by lilyoyo1
21 minutes ago, Michel Kohanim said:
@lilyoyo1,
Factory reset: press and hold the reset button for 30 seconds.
So, even if you use Admin Console | Cloud, you don't get anything?
I had already tried the factory reset but when I went into polyglot every still showed. I deleted everything but wanted to make sure polisy was cleared too. Thank you
Cloud works as far as pulling the admin console up. The default password worked.
Edited by lilyoyo1
19 minutes ago, Michel Kohanim said:
@lilyoyo1,
If cloud works but local does not work,
sudo pkg remove isy
sudo pkg install isy
That did it. Thank you for your help. As always, you're the best
54 minutes ago, Michel Kohanim said:
@lilyoyo1,
sudo pkg remove isy
Spoke to soon. While I'm able to get in now, i do not have the portal. Manage modules shows all up to date but does not show the portal in help>about. No portal tab either under the Configjuration tab.
Added polisy to my portal account. Shows as my preferred Isy but is currently offline
