Program wait with door sensor
Having issue trying to get this to work. What am i missing. Front door open want lights on for 25 min then turn off. Right now light turn on then when door shut they turn off.3b238059a3d552a419baf626017d2eda.jpg
Sent from my SM-G960U using Tapatalk
Start by giving us a better view of your program. Right click on your program name and select copy to clipboard. Then paste your program here.
Can't see your p program. However, if you're using insteon and the sensor is linked directly to your switch, then it will do what you are experiencing
Entry light - [id 0017] [parent 0007]
Front door is switched on
In 'side door drvwy - A' Set 'dining room ceiling lifght' to On, No retries
Wait 25 minutes
In 'Side door drvwy - A Set 'dining room ceiling light ' to Off, No retries
This is the program you need.
If status front door is on
Set dining room light on
wait 25 minutes
Set dining room light off
(blank)
