MyQ PG3 Node server Released
I have released the PG3 version of the MyQ Node server (v3.0.18). Installation instructions, release notes, and version history can be found here: https://github.com/Goose66/NSDocs/blob/main/myq-pg3.md.
There is a 3-month trial period and then the Node server is $12.95 a year. I decided on an annual subscription for this one since I am generally required to update it a couple of times a year to keep it running.
Edited by Goose66
  • 10 months later...
I have uploaded a new version of the MyQ Node Server (v3.1.20) to the Node Server Store. This version slightly changes the way initial connections are made on restart and adds Low Battery and No Comms states to garage door openers to support door position sensors (DPS). See release notes at https://github.com/Goose66/NSDocs/blob/main/myq-pg3.md for more info.
  • 8 months later...
I have uploaded a new version of the MyQ Node Server (v3.2.22) to the Node Server Store. This version adds a User-Agent header to the oAuth calls as well as the API calls to get around the 403 unauthorized values. It also adds a new driver value for the MyQ Service node that is a Node Server Status value managed by PG3. See release notes at https://github.com/Goose66/NSDocs/blob/main/myq-pg3.md for more info.
  • 4 weeks later...
I have uploaded a new version of the MyQ Node Server (v3.2.23) to the Node Server Store. This version implements fixes to oAuth to try and keep up with the changes coming from Chamberlain. I would like to say this version should work for some time, however, I feel like we are chasing our tails right now with this and the node server is getting quite fragile. When it has a valid token, it works great. But every time you restart the node server (or potentially every 60 minutes when in refreshes the token) there is a chance that the authentication will fail. There are also a couple of bugs in this version that occur in rare network conditions that will take some time to run down, but I wanted to get a semi-working version out to you guys as fast as possible.
