WeatherBit PG3 Forecasts not showing in ISY
I have installed it multiple times.  It all loaded fine this last time.  Then I rebooted the ISY and new data is not coming into the ISY but if I look at the nodes in PG3 there is data there (not zeros).  So it should show something.
I attached a log.
Giving up for the night so will try again tomorrow
WeatherBit_2-17-2022_122826_AM.zip
I installed the nodeserver again and worked fine until it errored again.
Once it stops it stops updating in the ISY too but polisy still shows it connected.
I either have the old values in ISY but if I reboot ISY and it worked.
thinking of going back to the Pg2 server for now.
I do have all the other weather nodeservers working
forgot to paste the error and see screen shot.  Does not show online
2022-02-17 01:02:58,878 MQTT udi_interface.interface ERROR interface:_message: error No valid API calls provided 2022-02-17 01:02:58,879 MQTT udi_interface.interface ERROR interface:_message: Invalid command received in message from PG3: 'message' {"set":[{"address":"forecast_10","driver":"GV19","value":6,"uom":25},{"address":"forecast_10","driver":"GV0","value":35.3,"uom":17},{"address":"forecast_10","driver":"GV1","value":21.4,"uom":17},{"address":"forecast_10","driver":"CLIHUM","value":41,"uom":22},{"address":"forecast_10","driver":"DEWPT","value":6.1,"uom":17},{"address":"forecast_10","driver":"BARPRES","value":1012.8,"uom":117},{"address":"forecast_10","driver":"GV13","value":801,"uom":25},{"address":"forecast_10","driver":"GV14","value":3,"uom":22},{"address":"forecast_10","driver":"GV4","value":13,"uom":48},{"address":"forecast_10","driver":"GV5","value":21,"uom":48},{"address":"forecast_10","driver":"WINDDIR","value":330,"uom":76},{"address":"forecast_10","driver":"GV6","value":0,"uom":105},{"address":"forecast_10","driver":"GV7","value":0,"uom":105},{"address":"forecast_10","driver":"GV8","value":0,"uom":105},{"address":"forecast_10","driver":"GV18","value":0,"uom":22},{"address":"forecast_10","driver":"GV16","value":5.2,"uom":71},{"address":"forecast_10","driver":"GV10","value":313.6,"uom":56},{"address":"forecast_10","driver":"GV15","value":15,"uom":116},{"address":"forecast_10","driver":"GV9","value":0.11,"uom":56},{"address":"forecast_10","driver":"GV20","value":0.083,"uom":106}]}
btw  I am on the free api.
I got a second one and going to run pg2 and pg3 version at same time so I can use pg2 for stuff and help you work out bugs on other version.
attached is another log file.
ITS UPDATING the controller main after a restart.,  It seems to be just the forecast that are not updating but they do update after a reinstall of nodeserver
WeatherBit_2-17-2022_80241_AM.zip
this is what bothers me
2022-02-17 08:08:54,363 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_0 not found in database. 2022-02-17 08:08:56,457 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_1 not found in database.
2022-02-17 08:09:12,602 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_2 not found in database.
2022-02-17 08:09:28,679 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_3 not found in database.
2022-02-17 08:09:40,773 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_4 not found in database.
2022-02-17 08:09:48,821 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_5 not found in database.
2022-02-17 08:09:56,845 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_6 not found in database.
2022-02-17 08:10:10,891 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_7 not found in database.
2022-02-17 08:10:21,025 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_8 not found in database.
2022-02-17 08:10:29,055 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_9 not found in database.
2022-02-17 08:10:39,193 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_10 not found in database.
2022-02-17 08:10:49,269 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_11 not found in database.
2022-02-17 08:10:55,310 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_12 not found in database.
2022-02-17 08:11:09,463 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_13 not found in database.
2022-02-17 08:11:15,484 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_14 not found in database.
2022-02-17 08:11:25,625 Thread-5 udi_interface.interface ERROR interface:db_getNodeDrivers: forecast_15 not found in database.
so far so good.  It seems to be updating now.  I will leave Pg2 and pg3 versions installed for a bit.
as far as the other bug I posted about the Evapotransporation I will update that post next
Will post here later with final OK!!
