Old Surfer Dude Posted February 20, 2022 Posted February 20, 2022 I have a scene with three devices, one of them is the load, the other two are buttons on a keypad. I have a sensor, not in the scene, that triggers the scene to turn ONoff. But the devices don't respond. To add to the challenge, When I look at the scene in the [Main] tab, the devices are indicated as being ONoff but they are not in that state. As a work around, in the program, I issue the command ONoff three times. Interestingly enough, this also occurs when I manually turn ONoff the scene from the ISY in the [Main] tab. The scene works as expected when using the members of the scene. (I use ONoff to indicate both situations of ON or off) My goal is to have the sensor turn ONoff the scene, but not during the day and not if one of the of the buttons had turn the scene on Program to respond to sensor FrontPorchSensorONoff - [ID 0009][Parent 0001] If From Sunset To Sunrise (next day) And ( '- / FrontPorchSensor-Sensor' is switched On And '- / FrontPorchSensor-Sensor' is not switched Off ) Or $PorchLightPersistOn is 1 Then Set 'FrontPorchLights' On Set 'FrontPorchLights' On Set 'FrontPorchLights' On Else Set 'FrontPorchLights' Off Set 'FrontPorchLights' Off Set 'FrontPorchLights' Off Program to set persistence Want to keep the porch lights from coming on during the day. But, if manually switched on, turn them on no matter what and keep them on. For reasons unknown, 3 commands to turn ONoff lights are required to make it work. Program to set persistence FrontPorchPersistsON - [ID 000A][Parent 0001] If ( '- / FrontPorchLights' is switched On Or '- / Entry.Ed_FrontPorch' is switched On Or '- / Stairs.E_FrontPorch' is switched On ) And ( '- / FrontPorchLights' is not switched Off And '- / Entry.Ed_FrontPorch' is not switched Off And '- / Stairs.E_FrontPorch' is not switched Off ) Then $PorchLightPersistOn = 1 Else $PorchLightPersistOn = 0 Set a flag to ensure that the lights remain on
lilyoyo1 Posted February 20, 2022 Posted February 20, 2022 It would be helpful if you stated the devices you are using along with the firmware and UI. The ISY and Polisy supports many types of devices which can have many different ways to troubleshoot
brians Posted February 20, 2022 Posted February 20, 2022 Sounds to me like either: - communication problem with your ISY/PLM and the devices... maybe failing PLM? - failing devices that don't respond reliable correctly to Insteon commands. Are these switches older PLC only or Dual band with RF? An Insteon device in scene communicate amongst themselves directly without a controller which explains why they work with each other but not from ISY if there is a communication path issue somewhere.
Old Surfer Dude Posted February 20, 2022 Author Posted February 20, 2022 Thanks for your input! I have not experienced other communication problems between the devices the PLM/ISY Like I stated, I have an inelegant work-around, but it is always concerning that this may be evidence of other problems. ISY Firmware Insteon_UD994 v.5.3.0 (2020-10-01-14:39:56) UI Insteon_UD994 v.5.3.0 ( 2020-10-01-14:39:56) Product ISY 994i/IR (1130) - OpenADR (21010) - Z-Wave (21100) - Portal Integration - UDI (21075)Devices: FrontPorchSensor-Sensor 2842-222 INSTEON Motion Sensor v.41 FrontPorchLights 2442-222 Micro Module Dimmer v.43 Entry.Ed_FrontPorch: 2486D KeypadLinc Dimmer v.2A Stairs.E_FrontPorch: 2334-2 KeypadLinc Dimmer 8 Buttons V.45 ps, is there a way to turn off the double spacing? OSD
Geddy Posted February 20, 2022 Posted February 20, 2022 37 minutes ago, GFerry said: ps, is there a way to turn off the double spacing? Welcome to the forums. Enter currently starts a new paragraph. Putting space between the prior to make it easier for people to read. If you just want to go to the next line you can use space+enter and it will drop to the next line. Additionally, I would suggest updating to 5.3.4 firmware/UI as it's the latest version and while might not directly fix your issues it would be the most recent firmware that is supported and any troubleshooting or suggestions for adjustments given here will more than likely be based on current function of 5.3.4 firmware. Make sure you following directions carefully when upgrading firmware. 1
brians Posted March 4, 2022 Posted March 4, 2022 Is there another insteon device you can get the program to turn on/off besides the 2442-222? Your insteon network is not that big and there may be communications issues from your PLM to that particular device. Your one dimmer 2486D is single band and may have issues rebroadcasting the signal from PLM, or may be causing interference. Is it possible for testing to move the ISY and PLM closer and then test? In the past when I had more PLC only devices I would resort to similar programs to send the commands several times, but even so it was unreliable. As I have mostly dual band devices and about 50 Insteon devices in total, my network is pretty reliable now, but it was not that long ago that I have had similar issues. I recently changed out an ancient keypadlinc relay with a new dual band keypadlinc dimmer (no relays available) and it solved a whole bunch of communication issues with lights nearby that were associated with it. 1
Old Surfer Dude Posted March 4, 2022 Author Posted March 4, 2022 Thanks @brians Unfortunately, insteon products are in short supply and if you find one, it costs a lot. I am in the process of migrating to polygot to be able to use more cost effect devices. Alas, that is turning into a nightmare, too. OSD
