Please help with program
Hi,
I'm trying to write a simple program to reset the energy meter on a Zooz power switch every 30 minutes.
I attached a photo. This doesn't seem to be working.
Please help. Thanks.
Bob
37 minutes ago, BobM99 said:
Hi,
Bob
You have a useless Repeat construct. The lines to be repeated are found indented under the repeat loop construct command.
To terminate the repeat loop use Repeat 1 times after the lines you want repeated.
Repeat every 30 minutes
.....do something in a loop
Repeat 1 times
do the rest only once.
If you want two condition you can use this construct
Repeat 20 times
....do something 20 times
....Wait 20 minutes
Repeat 1 times
Do more lines only once
Etc...
Move your Repeat line up one.
Repeat 1 times
When does it jump out of "repeat every 30 minutes"?  What makes it jump to Repeat 1 times?
  • Haha 1
Am also wondering if in @BobM99 case, if he reversed the two program lines, will the program turn false during the reboot, which would stop the repeat, and then turn true again once on, causing a loop effect less than the 30 minutes.
My suggestion would be to have the following, assuming he wants it running all the time:
Program 1:
IF time is 2am
Then run THEN of program 2
Program 2:
THEN:
repeat every 30min
reset zoom.
This way, the program will always be running and if it were to stop due to reboot etc, it will start up again every day.
  • Like 1
I also tend to make loops like this occur at odd times, so that there is a less likely chance be data collisions.  That is, instead of happening every 30 minutes exactly on the half and and hour, I'll mix it up:
DoorOpenLight.Query - [ID 014C][Parent 0034]
        From     5:28:28AM
        To      11:59:59PM (same day)
        Repeat Every  33 minutes and 33 seconds
           Set 'Garage Entryway+# / Door Open' Query
  • Like 1
Posted (edited)
You could instead just alter your program to run every 30 minutes:
If       'ZW 016 On-Off Power Switch' Status is On
     And Time is Last Run Time for 'Reset kWh sump 2' + 30 minutes
        Set 'ZW 016 Energy Meter Sump 2' Reset
Make sure "Run at Startup" is Enabled.
Edited by Goose66
  • Like 1
Success!
First I reordered the repeat line as suggested by @larryllix. It still didn't work.
Then I created 2 programs as suggested by @dbwarner5. It now works perfectly.
Thanks to everyone who responded, and in general thanks to all who make this forum invaluable.
Bob
  • Like 3
Posted (edited)
Good catch! Repeats usually need a terminator so that following lines don't repeat in a loop fashion also. In this case of an infinitely repeating time loop, there is "no out".
UDI needs to implement a Break on xxxxxx condition construct yet.
  • Like 1
      38k
      379.3k
