ISY on Polisy (IoP) v5.4.0 - OUTDATED
OUTDATED - This version has been updated and is obsolete.
Please see the current release found in the Current Release area of the forums.
Hello all,
We are very happy to introduce IoP v5.4 which includes many new enhancements and bug fixes.
If you are new to Polisy, please do make sure to review Polisy User Guide
To upgrade, you have a few choices:
- Click the button on the front of the unit only once and wait for the beep (best option)
- In the Admin Console, click on Help | Automatically Upgrade Polisy menu
- If you are a geek, ssh and:
sudo pkg update && sudo pkg upgrade && sudo service isy restart
Bug fixes:
- A10/X10 menu missing
- UUID tied to the wrong port
- Added WebSocket Protocol header back but it's not checked
- Fixed User Web Directory access failure
- Added customized notifications to node servers
- Fixed ISY Portal module not persisting after backup/restore
- Error log formatting
- Network resources malformed when using URL encoding. Follow these instructions
${sys.node.#.name:url}  - URL encodes the resulting string
${sys.node.#.name:std} -  Does standard formatting (as done currently)
${sys.node.#.name} – Does default formatting (currently same as using “:std”)
Enhancements :
- Added Gallon per hour
- You can now use the extra network ports as a network switch. To enable/disable, please go to Admin Console | Configuration tab | | Network Settings | Network Switch Mode (ON)
- Added support for TPM basic TPM operations (such as enable/disable). To enable/disable, please go to Admin Console | Configuration tab | Security
- UEFI image. Currently, Polisy uses BIOS which does not support TPM boot. If the 3rd light is blinking, it means that you still have BIOS and not UEFI. You can click the button on the front 6 times consecutively and UEFI will be installed. This said, at this juncture, this is NOT mandatory
Important Note:
This version of IoP requires a few packages that come with udx 2.6. If for any reasons IoP is not working properly, it's mostly because udx was not automatically upgraded in the process. If that happens, please do let us know.
