Short term PGC Alternative?
@Michel Kohanim Other than purchasing the POLISY, are there any show term alternatives till PGC is back?  I seemed to recall a guide on running the node server on a RPI but cant find it now.
TIA
Ron
TIA
Ron
There are some nodeservers that can run on an RPI but not all. If the nodeserver you want is on this list, then you are able to set it up on an RPI to use. Just know, now that PG3 is out, most developers probably will not update those on PG2 so they may not continue to work
