Ecobee API Key error
I get this error...
api_key is not defined, must be running local version or there was an error retreiving it from PG3? Must fix or add custom param for local
I was getting this error, and a couple others stating that was expired and must re-key.
I deleted the app in my ecobee account, tried uninstalling and re-installing the Node server and all I get is this error now.
Edited by brians
@JimboAutomatesI noticed the log package contains pg3-current.log which has logins and passwords for all my PG3 nodes. debug.log looks ok, I will send you that for now until I look over other log to make sure.
I have the same issue now.  I tried rebooting.  Do you want me to PM you my logs?
Jeff
invalid_grant: The authorization grant, token or credentials are invalid, expired, revoked, do not match the redirection URI used in the authorization request, or was issued to another client.
Token expired -160978.383796 seconds ago, so will have to re-auth...
3.0.47   It came in about a day or so ago via sudo pkg upgrade.
There was a bug in 3.0.46 with backup he was fixing so I was checking every night for an update.
So I guess that broke it.
