PG3 Sonos Node server needs daily restart
Hi. My PG3 Sonos Node server needs a daily restart to work.  Every morning I start the day with the Node server not working. I cannot send any control to my Sonos using the PG3 Sonos Node server.  I can send commands to Sonos through IFTTT and the Sonos iOS app . Once I restart the Node server, I have normal control through the Node server - I can send Play, Pause, Volume adjustments. I am running ISY on Polisy and using a static address for my Sonos.  This has been happening since I installation of IoP.
Thank you for any suggestions!
Here is the log from this morning:
2022-04-03 02:22:05,160 Command    udi_interface      INFO     sonos-poly:_pause: Transition not available. This typically means no music is selected.
2022-04-03 02:22:23,788 Command    udi_interface      INFO     sonos-poly:_play: Transition not available. This typically means no music is selected.
2022-04-03 02:22:27,971 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 90 UOM 51
2022-04-03 02:22:30,376 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 85 UOM 51
2022-04-03 02:22:31,805 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 80 UOM 51
2022-04-03 02:22:32,450 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 75 UOM 51
2022-04-03 02:22:33,576 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 80 UOM 51
2022-04-03 02:22:34,455 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 85 UOM 51
2022-04-03 02:22:35,000 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 90 UOM 51
2022-04-03 02:22:38,125 Command    udi_interface      INFO     sonos-poly:_pause: Transition not available. This typically means no music is selected.
2022-04-03 02:22:41,704 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 80 UOM 51
2022-04-03 02:22:42,868 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 70 UOM 51
2022-04-03 02:22:43,771 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 60 UOM 51
2022-04-03 02:22:44,977 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 50 UOM 51
2022-04-03 02:22:46,034 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 40 UOM 51
2022-04-03 02:22:49,987 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 85 UOM 51
2022-04-03 02:23:00,407 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: ST to 2 UOM 25
2022-04-03 03:05:17,194 Command    udi_interface      ERROR    udi_interface:write: Exception in thread
2022-04-03 03:05:17,196 Command    udi_interface      ERROR    udi_interface:write: Command
2022-04-03 03:05:17,196 Command    udi_interface      ERROR    udi_interface:write: :
2022-04-03 03:05:17,197 Command    udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-04-03 03:05:17,198 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
2022-04-03 03:05:17,204 Command    udi_interface      ERROR    udi_interface:write: self.run()
2022-04-03 03:05:17,205 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run
2022-04-03 03:05:17,208 Command    udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-04-03 03:05:17,209 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/udi_interface/interface.py", line 678, in _parseInput
2022-04-03 03:05:17,213 Command    udi_interface      ERROR    udi_interface:write: self._handleInput(key, input[key], None)
2022-04-03 03:05:17,214 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/udi_interface/interface.py", line 809, in _handleInput
2022-04-03 03:05:17,218 Command    udi_interface      ERROR    udi_interface:write: self.nodes_internal[item['address']].query()
2022-04-03 03:05:17,219 Command    udi_interface      ERROR    udi_interface:write: File "./sonos-poly.py", line 80, in query
2022-04-03 03:05:17,221 Command    udi_interface      ERROR    udi_interface:write: self.update()
2022-04-03 03:05:17,221 Command    udi_interface      ERROR    udi_interface:write: TypeError
2022-04-03 03:05:17,222 Command    udi_interface      ERROR    udi_interface:write: :
2022-04-03 03:05:17,222 Command    udi_interface      ERROR    udi_interface:write: update() missing 1 required positional argument: 'pollflag'
2022-04-03 11:14:11,500 MainThread udi_interface      INFO     polylogger:set_basic_config: set_basic_config: enable=True level=30
2022-04-03 11:14:13,900 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.38 Starting...
2022-04-03 11:14:14,082 MainThread udi_interface.interface INFO     interface:__init__: Initialization received from Polyglot V3 3.0.45  [ISY: 5.4.1, Slot: 4]
2022-04-03 11:14:14,084 MainThread udi_interface.interface INFO     interface:__init__: Connect: Network Interface: {'addr': '192.168.1.128', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'}
2022-04-03 11:14:14,086 Interface  udi_interface.interface INFO     interface:_startMqtt: Connecting to MQTT... localhost:1888
2022-04-03 11:14:14,094 MainThread udi_interface.interface WARNING  interface:send: MQTT Send waiting on connection :: {'set': [{'key': 'customparamsdoc', 'value': ''}]}
2022-04-03 11:14:14,188 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Connected with result code 0 (Success)
2022-04-03 11:14:14,190 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:59:3a:98_4 -  MID: 1 Result: 0
2022-04-03 11:14:14,202 MQTT       udi_interface.interface INFO     interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,)
2022-04-03 11:14:17,116 MainThread udi_interface.interface INFO     interface:updateProfile: Sending Install Profile command to Polyglot.
2022-04-03 11:14:17,120 MainThread udi_interface      INFO     sonos-poly:start: Starting Sonos Polyglot v3 Node server version 3.0.0, udi_interface: 3.0.38
2022-04-03 11:14:17,121 MainThread udi_interface      INFO     sonos-poly:discover: Starting Speaker Discovery...
2022-04-03 11:14:17,121 MainThread udi_interface.custom INFO     custom:_save: Sending data notices to Polyglot.
2022-04-03 11:14:17,155 MQTT       udi_interface.interface INFO     interface:_message: custom data response {'customparamsdoc': ''}
2022-04-03 11:14:17,162 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = customparamsdoc
2022-04-03 11:14:17,401 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2022-04-03 11:14:17,415 MainThread udi_interface      INFO     sonos-poly:discover: Found 2 Speaker(s)
2022-04-03 11:14:17,451 MainThread udi_interface      INFO     sonos-poly:__init__: Sonos Speaker: Lounge@192.168.1.167 Current Volume: 61
2022-04-03 11:14:17,453 MainThread udi_interface.interface INFO     interface:addNode: Adding node Sonos Lounge(caafd43b6f6014) [None]
2022-04-03 11:14:17,532 MainThread udi_interface      INFO     sonos-poly:__init__: Sonos Speaker: Sonos@192.168.1.127 Current Volume: 70
2022-04-03 11:14:17,534 MainThread udi_interface.interface INFO     interface:addNode: Adding node Sonos Sonos(8e937957fe8014) [None]
2022-04-03 11:14:17,714 MQTT       udi_interface.interface INFO     interface:_message: Profile installation finished
2022-04-03 11:14:19,239 Thread-2   udi_interface      INFO     sonos-poly:start: Sonos Lounge ready to rock!
2022-04-03 11:14:19,319 Thread-4   udi_interface      INFO     sonos-poly:start: Sonos Sonos ready to rock!
2022-04-03 11:14:20,198 MQTT       udi_interface.interface INFO     interface:_message: Successfully set caafd43b6f6014 :: SVOL to 61 UOM 51
2022-04-03 11:14:20,291 MQTT       udi_interface.interface INFO     interface:_message: Successfully set caafd43b6f6014 :: GV1 to 0 UOM 56
2022-04-03 11:14:20,408 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: ST to 0 UOM 25
2022-04-03 11:14:20,489 MQTT       udi_interface.interface INFO     interface:_message: Successfully set caafd43b6f6014 :: GV2 to 0 UOM 56
2022-04-03 11:14:20,604 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: SVOL to 70 UOM 51
2022-04-03 11:14:20,691 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: GV1 to 0 UOM 56
2022-04-03 11:14:20,792 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: GV2 to 0 UOM 56
2022-04-03 11:14:53,881 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: ST to 2 UOM 25
2022-04-03 11:14:57,099 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: ST to 1 UOM 25
2022-04-03 11:15:45,518 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: ST to 2 UOM 25
2022-04-03 11:15:47,420 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: ST to 3 UOM 25
2022-04-03 11:15:49,678 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8e937957fe8014 :: ST to 1 UOM 25
Solved by bpwwer
I have to restart my PG2 Sonos Node server every few days.  @Michel Kohanimand others have looked at my logs and concluded it was a problem with my network.  I dunno.  I have several ways of controlling my Sonos system and the others all work perfectly.
Edited by carealtor
I just pushed version 3.0.1 to the node server store.  This version should stop it from crashing.
Restarting the node server, should auto update it.  If that doesn't work, let me know.
This may not be related to your issue or the Node server, but if you have a mesh WiFi network, then some Sonos installations can have problems staying continuously connected to WiFi.  Two solutions have worked to solve this issue in the couple of networks that I've had to deal with: 1) connect one Sonos speaker to the network with an ethernet cable instead of WiFi, or 2) add a Sonos Boost to the network.
If the problem continues and you have a mesh WiFi setup, this may solve your issue.
It has been over 24 hours since the update and the connection remains stable.  Thank you @bpwwer
