How to refresh the install of a node (Weatherflow) on PG3
Transitioning to Polisy from my ISY, and surprisingly everything is going pretty well! (the surprise more a comment on me than anything else). I read through the wiki and a number of critical posts here, which I suppose helped.
BUT, one issue. To have a look at it, I bought and installed the Weatherflow node (PG3) on the yet "empty" Polisy. Installed fine, I could see it. and play with it. All good.
I then restored my ISY994 programming setup, the kind of final step in the ISY migration, and the Weatherflow node server disappeared on the Polisy. Not surprising I guess. I tried to run a reinstall of WF/PG3 from the PG3 interface, but when getting to the choosing the slot step (slot 5 in my instance), that slot is no longer showing as an available target.
So, the issue is a mis-coordination between PG3, by my wiping out the WF node with the restore.
How do I force a fresh install of the WF/PG3 node in my Polisy?
Do I need to delete the node in the PG3 interface, and do a "do over" install?
* Orest
Edited by oskrypuch
Looks like it was two issues, kind of.
The restore reset the password to default. Fixed that, expect it would have blocked PG3's access. Then I deleted the node in PG3, reinstalled, and then I did a Query in the Node Servers menu again to load the node.
It's there now. Now just waiting for my Tempest!
* Orest
Edited by oskrypuch
