Question about event viewer entries
Can anyone tell me what these mean?:
Fri 04/22/2022 04:21:30 PM : [FileOpen    ] Open failed for [/CONF/122.PRP] (r)
Fri 04/22/2022 04:24:31 PM : [FileOpen    ] Open failed for [/CONF/143.PRP] (r)
Fri 04/22/2022 04:24:53 PM : [FileOpen    ] Open failed for [/CONF/30.PRP] (r)
Fri 04/22/2022 04:30:38 PM : [FileOpen    ] Open failed for [/CONF/16.PRP] (r)
Fri 04/22/2022 04:32:05 PM : [FileOpen    ] Open failed for [/CONF/17.PRP] (r)
Fri 04/22/2022 04:32:52 PM : [FileOpen    ] Open failed for [/CONF/49.PRP] (r)
Fri 04/22/2022 04:33:02 PM : [FileOpen    ] Open failed for [/CONF/48.PRP] (r)
Fri 04/22/2022 04:33:58 PM : [FileOpen    ] Open failed for [/CONF/42.PRP] (r)
Fri 04/22/2022 04:36:41 PM : [FileOpen    ] Open failed for [/CONF/94.PRP] (r)
Fri 04/22/2022 04:38:06 PM : [FileOpen    ] Open failed for [/CONF/92.PRP] (r)
Fri 04/22/2022 04:39:53 PM : [FileOpen    ] Open failed for [/CONF/100.PRP] (r)
Fri 04/22/2022 04:40:19 PM : [        Time] 16:40:22 0(0)
Fri 04/22/2022 04:40:40 PM : [FileOpen    ] Open failed for [/CONF/91.PRP] (r)
I took a look at my ISY944i event viewer today and found a bunch of the above.
Edited by Wes Westhaver
Solved by Michel Kohanim
for the fastest answer open a ticket, support@universal-devices.com
as someone who reads the forum daily, I don't recall a similar question.
Thanks, I'll do that.
16 hours ago, Michel Kohanim said:
@Wes Westhaver,
Those are files that describe notes for nodes. If you are using MobiLinc Connect, that's probably the cause because it queries all the notes for nodes. But, if there are no notes, you see that line in the error log. It's completely benign.
@Michel Kohanim I don't use MobilLinc so that would not apply here. I've been exploring the Admin Console a bit and did run a "Tools | Generate Topology" report which includes node notes. Could that have generated those Event Viewer entries?
