Polisy pro vs std
any advantages to going with the pro?  WiFi added, but what would I use that for?  Network connection?  I have an network switch nearby, so no advantage, right?
From the Polisy spec sheet:
Native support for 3G/4G modems gives you the ability to go off the grid. Literally! And, if you are one of those maximum-connectivity types, this model –  Polisy PRO – comes standard with Dual Band WiFi and Bluetooth (4.0)
what would the wifi be used for, connection to the network?
At this point you don't need the "Pro" option of polisy, neither of the radio's (wifi or bluetooth) is implemented.  If you need it in the future, I'm certain there will be an upgrade kit.
I did find an advantage of having a Pro when I migrated.  I had some Z-Wave devices in difficult locations that I could not exclude or include from the default Polisy location, and I didn't have a long enough ethernet cable to move the Polisy closer.  The solution was to enable WiFi on the Polisy, and move the Polisy close to the Z-Wave devices to enable exclusion/inclusion.  These devices are older devices such as Schlage locks, etc.  Worked like a charm.
Fantastic. I’m planning my migration to Polisy IoP and PG3. Using WiFi may be needed for my Schlage deadbolts.
The only 'gotcha' with doing this is that if you've already migrated your Insteon devices, you'll get lots of pop-up notices in the AC about unavailable Insteon devices unless you also plug in a PLM (I used a spare) or turn off Insteon support in the AC prior to the restart.  Not a big deal, but something to note.
Edited by Bumbershoot
17 minutes ago, Bumbershoot said:
The only 'gotcha' with doing this is that if you've already migrated your Insteon devices, you'll get lots of pop-up notices in the AC about unavailable Insteon devices unless when you also plug in a PLM (I used a spare) or turn off Insteon support in the AC prior to the restart.  Not a big deal, but something to note.
