Is it possible to use the portal URL to add a remote Polisy?
Is it possible to use the portal address to access a remote Polisy? I don't want to have to poke a hole in the firewall to allow remote management of the Polisy. When I use the portal URL in place of the IP address it fails to add the Polisy.
Example only:
Admin Console URL: https://my.isy.io/isy/2389687e62f28763e207962a298746b/desc
Since PG3 supports multiple Polyglot's I was trying to use the Portal URL to add a remote Polisy to PG3 without any success. Just trying to see if there might be a way to accomplish this without using a VPN or port forwarding in the router.
I expected that was you're endpoint.
I need a vpn for other services so I just use it.
Do you know what the Node Server listing is for in Portal? Maybe that was a place holder for access.
