[Solved] Beta Unit - can't get past ver 12.2
G W
Posted (edited)
On 1/18/2022 at 4:36 PM, Michel Kohanim said:
Thank you. There was a bug with udx ... please do the following:
sudo pkg update && sudo pkg upgrade
sudo service udx restart
sudo service isy restart
Reload your backup.
I need help.  I can't get past 12.2. The ISY Finder will not find the polisy. I have tried to Add it with https://192.168.2.45:8443/desc, http://192.168.2.45:8443/desc and all other variations. This is one of the original Beta units.
[admin@polisy ~]$ sudo pkg update && sudo pkg upgrade
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[admin@polisy ~]$ pkg info udx
pkg: No package(s) matching udx
[admin@polisy ~]$ pkg info isy
pkg: No package(s) matching isy
[admin@polisy ~]$ sudo uname -a
FreeBSD polisy 12.2-RELEASE-p6 FreeBSD 12.2-RELEASE-p6 r369564 POLISY  amd64
[admin@polisy ~]$ curl -s https://pkg.isy.io/script/update121.sh | sudo bash
Password:
Nothing to do.
Installing FreeBSD-base updates
Fetching meta.conf: 100%    163 B   0.2kB/s    00:01
Fetching packagesite.txz: 100%   20 KiB  20.4kB/s    00:01
Processing entries: 100%
FreeBSD-base repository update completed. 284 packages processed.
The most recent versions of packages are already installed
lookig for .pkgnew files...
Preserving files that are unique to Polisy
lookig for any left over .pkgnew files...
Upgrade complete, please reboot using: sudo shutdown -r now
[admin@polisy ~]$
[admin@polisy ~]$  cat /usr/local/etc/udx.d/static/update13.sh | sudo bash
cat: /usr/local/etc/udx.d/static/update13.sh: No such file or directory
Edited by Gary Funk
@Gary Funk
Give this a go. I think it will get you up and running.
Upgrade Original PoliSy (without the packaged kernel)
Wait for the unit to reboot, up to twenty minutes, then:
49 minutes ago, kzboray said:
@Gary Funk
That's exactly the steps I did and the results are in my post.
4 hours ago, Gary Funk said:
I tried that and more.
If you haven't done so yet, the bios on that machine will most likely not have been upgraded to EUFI.  6 successive presses on the front panel button will force an upgrade to EUFI.  I think that the 'udx' service now requires that.
Probably best to open a ticket, however.
did you reboot between
and
Note this line at the bottom of the 121.sh
and
Yes, I did. It spent more time rebooting than most cities have boot.
I think the issue was that 13.sh never didn't happen because the command failed.
It's fixed now.  Thank you, @Michel Kohanim
I thought is was fixed.
[admin@polisy ~]$ sudo service udx restart
udx does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d), or is not executable
The Polisy is online.
I gave it my best but in the end, the Polisy refused to play nice. My punishment for negotiating it over the years. I updated Michel on my lack of progress and the latest observations.
Monday morning, through a remote session, Michel tickled the keys on his keyboard and convinced Polisy to accept a completely new set of updates. A few minutes later the system completed the updated and came online.
The next step was to locate the serial cable which took a day to find. The actual backup and restore took less than four minutes. I was actually disappointed in the restore process. It happened so quick I didn't get to see it.
Well, Blueboy is online and the system is happy. I need to check the system and ensure all the links are in order. Support from UDI is still 100% and I'm great full for this community and the UDI staff.
Thank you, Michel.
  • Like 2
      38.1k
      380.1k
