Folders not showing
Having problems with a new imac showing up folders.  You cant open the folder but every thing is working in that folder.  The old mac shows every thing proper the problem is only with the new mac. any suggestions?
Paul
Screen Shot Folders.pdf Screen Shot ISY UUI.pdf
Solved by Javi
That is the problem its not there.  I did improve on it some what I can now open the folders by clicking where the chevron icon should be.
Paul
As @Javi says they are there...just very faint with the colors you're viewing them with. It could be a mac system color option, but the colors are limited in the admin console and can be set using themes (File Menu -> Theme -> Theme Color)
(from your PDF screenshot - tried to adjust colors to show the chevrons a little better)
Interesting difference in the macOS world...while in Windows 10 folders have the + next to them.
In Mac if you click or double click (or mac equivalent of a double click) does the folder open? It does in Windows so assume if you double click the folder it should expand or have similar operations in Mac.
Looks like the "Incoming Water Rm" is the only folder that doesn't have anything in it so it doesn't have a chevron to expand the folder.
Easy fix, thanks just have to open my eyes.
Paul
