January 18, 201016 yr I have a set of 5 buttons on an 8-button Keypadlinc set as a mutually exclusive group. For some reason, button A remains constantly lit regardless of the status of the other buttons. Is there any way to make button A behave the same as the rest in the group? - Dave
January 19, 201016 yr Hi Dave, Unfortunately not that I have been able to configure. Button A is the load on an 8 button KPL and although it works in grouping (i.e. turning a sub button can turn it on) but mutually exclusive buttons cannot turn it off. The best solution is to use a scene and change the on level to 2% (0 does not work) for each one of the buttons for which you wish mutual exclusivity. With kind regards, Michel
January 24, 201016 yr Author I'm not using the dimmer in the KPL, so I can easily add it and set it to off in other scenes. Are you saying that if I set it to 2% in my other scenes, the key's backlighting will turn off? Also - I have KPL button A set to trigger a scene. If I add it as a responder to other scenes (with the intention of controlling the button backlight), will those scenes the control the dimmer or the scene that KPL A is set to control? The later would obviously be a problem. - Dave
January 24, 201016 yr Hi Dave, This procedure is only for the following condition: 1. Button A is in the same scene as some other button (say button C) from the SAME KPL 2. You wish to have button A turn OFF when button C (on the SAME KPL) is turned on For all other scenes for which Button A is a responder (and as long as the controller is not on the same KPL) you can do as you would with any other device. I hope this makes sense. With kind regards, Michel I'm not using the dimmer in the KPL, so I can easily add it and set it to off in other scenes. Are you saying that if I set it to 2% in my other scenes, the key's backlighting will turn off? Also - I have KPL button A set to trigger a scene. If I add it as a responder to other scenes (with the intention of controlling the button backlight), will those scenes the control the dimmer or the scene that KPL A is set to control? The later would obviously be a problem. - Dave
January 30, 201016 yr Author I understand what you're saying, but I'm not sure that it's answering my question. I did some more testing and fooling around today so let me see if I can explain myself more clearly. First, all of my dimming and scenes are executing the way I want them to. The only thing I'm having problems with is the backlighting of button A on the KPL. I have an 8-button KPL and I want each of the buttons to control a scene. Five of the buttons (including A) are in a mutually exclusive group. The way I would like the backlight of the buttons to work is for one backlight to be lit at a time, depending on which scene is currently in use. I do not have any load connected to the KPL dimmer and it currently is not included as a responder in any scene. KPL A is set to Non-Toggle On and is in the mutually-exclusive group mentioned above. The problem I am having is that the backlight of button A seems to have a mind of its own. It does not behave as though it is part of the mutually exclusive group. If I press A multiple times in succession it toggles the backlight on and off, even though the lighting scene doesn't change. I tried adding KPL A as a responder in scenes controlled by the other buttons, setting it to both 0% and 2%, but neither of these values cause the backlight to turn off. Does that make more sense? Is there something I'm doing wrong? - Dave
January 31, 201016 yr Hi Dave, I think I did answer the question but most probably not clearly. You see, unfortunately you can NOT put button A (or any KPL load button) in a mutually exclusive relationship with any other one of its buttons. I really wished I could help out here but this is completely outside of our control. With kind regards, Michel
