Substitution variable changes for soil moisture sensors
FYI - for anyone running reports using the soil moisture sensors, the reporting node (substitution variable) has changed in the PG3 version.  In the PG2 version, the variable MOIST would produce data in an emailed report (this example assumes that the EcoWitt Node server is installed in slot 5):
   ${sys.node.n005_wh51_1.MOIST}
In the PG3 version, the substitution variable has changed to ST:
   ${sys.node.n005_wh51_1.ST}
You'll need to edit your reports.
BTW, thanks @simplextech for the updated Node server!
Welcome.  I went through and changed all nodes to report proper status (ST) for those that like looking at the overall system status from the primary ISY node in Admin Console :)
