2nd Hue Hub
Does anyone know how to get a second Hue bridge setup on the NS?
I use two bridges and am trying to set up a second bridge on my NS. I looked at the v2 documentation but did not see anything about adding a second bridge.
There's a post on the Node server sub-forum where someone was able to use 2 bridges. It's titled similar to yours
this is from the post mentioned by @lilyoyo1.
On 10/13/2021 at 2:29 PM, deholt said:
lilyoyo1, I suspect you're correct about adding more bulbs vs dickering around with another bridge. However, the node server's author added a statement to "configuration help" which may have resolved my issue. A configuration option is to add a custom parameter key and value:
  • bridges - this should be set to the list of Hue bridges if you have multiple you would like to be able to control, for example: ["10.0.1.1","10.0.2.1"]
I invoked this option, restarted the node server, and two additional nodes were added! I'll play around with this setup, and see if it does what I am aiming.
Again, thanks to all.
setting this seems to have done the trick. It did cause a few issues with hue devices i had previously set up. anything with a name change was recreated and the original one in the ISY was left but the node did not work.
