How can I remove a link that I can't see in a scene
I have a KPL switch that is controlling something that is shouldn't.
I can see it in the linking table under diagnostics tab, but can not find it anywhere under programs or scences.
Anyway to get it out without a factory reset?
Hi AnthemAVM,
The best and least intrusive method is this:
1. If your KPL button is already a controller in a scene, then add the "something" in that scene as a responder and then remove it
2. If your KPL button is NOT already a controller in a scene, make scene, but the KPL button as a controller in the scene, add the "something" as the responder in the scene and then remove both as well as the scene
Hi AnthemAVM,
Worked perfect.
