Hello all
I am still learning as much as  I possibly can on my own about the isy/polisy. It's a huge learning curve with alot of little variables to check/ unchecked, verify and pretty much play around with until I get it right.
Unfortunately I am still waiting for my PLM serial cable so I have not been able to add any devices to my PLM yet.
What would helpful is if any one had any sample programs I could have a look at in order to better understand the process of how to make one when I'm ready.
I've tried simple ones like schedules, but I would really like to see what this POLISY can do.
For example : I want to use a insteon On/Off switch as a count down timer.  When the switch is turned on the timer immediately starts depending on what time I set it to count down from.
Stuff like that would be cool to learn how to do.
Help would be appreciated.
Solved by MrBill
15 minutes ago, Prana electric said:
Hello all
If you go to YouTube and type in Isy variables, they have some examples that can help you. Googling Isy cookbook will also bring up a guide that is still relevant.
36 minutes ago, Prana electric said:
Hello all
Study the ISY Cookbook--- a 692 page pdf of the examples you seek!
@Prana electric
Doesn't do anything much useful, but this is what you're asking for.
timer initialize could be triggered by something.
And presumably, you'd want something to happen when the counter reached zero.
$_counter would need to be a state variable. (I( use the underscore to label variables as state variables)
* Orest
timer initialize - [ID 01A4][Parent 0054]
        [some conditions or action for a trigger]
        Stop program 'timer run'
        $_counter  = 60
timer run - [ID 0094][Parent 0054]
        'family rm / FAM - pots' is switched On
        Repeat Every  1 second
           $_counter -= 1
timer stop - [ID 01B6][Parent 0054]
        $_counter <= 0
        Run Program 'timer initialize' (Then Path)
        Run [do something here]
Could also use a while loop for the counter, which is a little more efficient performance.
        Repeat While $counter > 0
           $_counter -= 1
Edited by oskrypuch
