andrew77 Posted May 29, 2022 Share Posted May 29, 2022 Theatre 25 - [ID 0012][Parent 0001] If Status 'Theatre Room' is Off And Control 'Theatre Room' is switched Off Then Set 'Theatre Room' 25% Else - No Actions - (To add one, press 'Action') I have a few programs like this and none of them work now. I tried deleting this program and doing it again but that didn't help either. In the GUI I can tell it to "Run Then" and it works I'm leaving a link to the other post where we were trying to fix my issues if that may be connected somehow. Timers are working and notifications are working. I didn't try to Restore ISY as I did that to get from the previous issue to where I am now Link to comment Share on other sites More sharing options...
MrBill Posted May 29, 2022 Share Posted May 29, 2022 This was discussed at length a month ago, have a read and let us know if that's the same as your issue. In summary, It looks like you need to right click the device and select "restore device". Link to comment Share on other sites More sharing options...
apostolakisl Posted May 29, 2022 Share Posted May 29, 2022 @andrew77 I went through and restored every single device on my network. Whatever the bug, I only found it affected this program style, but since it was a problem that was fixed by restoring the device, clearly the issue is with ISY/device links and there are bound to be some other funkiness that we just haven't noticed yet. Link to comment Share on other sites More sharing options...
oskrypuch Posted May 29, 2022 Share Posted May 29, 2022 6 hours ago, apostolakisl said: @andrew77 I went through and restored every single device on my network. Whatever the bug, I only found it affected this program style, but since it was a problem that was fixed by restoring the device, clearly the issue is with ISY/device links and there are bound to be some other funkiness that we just haven't noticed yet. All devices, not just 2477D units? Some years ago I went through and compared all the DEVICE and ISY links tables, for every device. I found quite a few (~20%) had disparities. I restored all those devices. Guess they go farkled gradually over the years. It would be nice to have an ISY function that can skip through all of your devices, make that comparison in batch, and then issue a report. * Orest Link to comment Share on other sites More sharing options...
andrew77 Posted May 30, 2022 Author Share Posted May 30, 2022 12 hours ago, apostolakisl said: @andrew77 I went through and restored every single device on my network. Whatever the bug, I only found it affected this program style, but since it was a problem that was fixed by restoring the device, clearly the issue is with ISY/device links and there are bound to be some other funkiness that we just haven't noticed yet. @apostolakisl I've started doing this and it seems to be working great. I have to delete the devices from the ISY and re add them in it seems as they won't restore. I'll keep the forum updated on my success Link to comment Share on other sites More sharing options...
apostolakisl Posted May 30, 2022 Share Posted May 30, 2022 11 hours ago, andrew77 said: @apostolakisl I've started doing this and it seems to be working great. I have to delete the devices from the ISY and re add them in it seems as they won't restore. I'll keep the forum updated on my success Shouldn't have to delete the device. Deleting will make for a boat load of work since the device will need to be configured from scratch. Just right click then hit restore. If that isn't doing anything, then I would put in a ticket. Link to comment Share on other sites More sharing options...
andrew77 Posted May 30, 2022 Author Share Posted May 30, 2022 20 minutes ago, apostolakisl said: Shouldn't have to delete the device. Deleting will make for a boat load of work since the device will need to be configured from scratch. Just right click then hit restore. If that isn't doing anything, then I would put in a ticket. I think I will do that. Thanks for the advice before I deleted stuff. If I tell Alexa to Turn On Entryway she says Entryway isnt responding. After Restoring She says Okay but the light doesn't turn on. Theres no Current state in the ISY and the device doesn't respond to GUI commands. Thanks for the help Link to comment Share on other sites More sharing options...
MrBill Posted May 30, 2022 Share Posted May 30, 2022 15 minutes ago, andrew77 said: If I tell Alexa to Turn On Entryway she says Entryway isnt responding. Open alexa in a computer browser at https//alexa.amazon.com and delete all the ISY devices and scenes then say "Alexa, discover devices" and let her add them back. Link to comment Share on other sites More sharing options...
andrew77 Posted May 30, 2022 Author Share Posted May 30, 2022 1 minute ago, MrBill said: Open alexa in a computer browser at https//alexa.amazon.com and delete all the ISY devices and scenes then say "Alexa, discover devices" and let her add them back. Delete all of them or just the non functioning ones? Link to comment Share on other sites More sharing options...
MrBill Posted May 30, 2022 Share Posted May 30, 2022 8 minutes ago, andrew77 said: Delete all of them or just the non functioning ones? either... i usually do all so I don't have to test all of them. Link to comment Share on other sites More sharing options...
andrew77 Posted May 30, 2022 Author Share Posted May 30, 2022 38 minutes ago, MrBill said: either... i usually do all so I don't have to test all of them. I did the troubled one to start. Still no luck. Do I have to airgap them? Link to comment Share on other sites More sharing options...
MrBill Posted May 30, 2022 Share Posted May 30, 2022 1 hour ago, andrew77 said: I did the troubled one to start. Still no luck. Do I have to airgap them? I've never had to, but maybe you don't have the same problem. Look and make sure there aren't duplicates on the alexa login to... that happans sometimes. when it does it's usually remove and re-add to Alexa to get rid of "<blank> isn't responding." Link to comment Share on other sites More sharing options...
