OpenWeather Map Node server Status goes blank
@bpwwer   After a period of time the Node server status goes blank. It appears the Noseserver is still running and updating the IOP. The NOAA Weather Node server is doing the same thing. Nothing shows in the log as they are still running. All other PG3 node servers that I am running do not have this issue. Frontend Version 3.0.62            ISY 5.4.4. Openweather Map 3.1.1
There have been changes to the way node servers work since this node server was ported.  The node server is not responsible for that status value, PG3 is.  I've updated the node server so it should work correctly with the latest PG3 design.
I'm running 5.4.4 and the latest .62 PG3. (just updated)
I'm still seeing blank "Node server Online" for OW & WB. What else do I need to do, or is this just something that is still coming down the pike?
My (Tempest) WeatherFlow node properly shows True for Node server Online
Many thanks for your work on providing these.
* Orest
Edited by oskrypuch
@bpwwer Thank you..  NOAA now reports True and Open Weather is reporting a 1 for online. I assume a 1 for online and a 0 for offline.  Thank you again for all your work.
Edited by tlightne
OK, so Node server Online shows 1 now.
However, doing an IF statement in ISY, only allows for % on that field, namely 0%, 1% & 2%. Ignoring that it is %, and just testing against 1% (or 0%), doesn't test as TRUE/FALSE.
Now, that might be an ISY thing, but this isn't working yet.
* Orest
Edited by oskrypuch
No, it's probably not an ISY thing, I must still have something wrong in the profile files or you don't have the most recent profile files loaded in the AC.  Here's what I see on mine:
Try the "Upload Profile" button on the PG3 node details page and then restart the AC.
OK, went into the OW node, and clicked Load Profile.
There was no alert or announcement, and the button stayed pushed, BUT on refresh of the AC I now see what you have depicted. So fixed.
* Orest
