Insteon 2441 Thermostat Sets to GMT
ae7nm
When I switched from an ISY 994 to ISY on Polisy, the set time command sets the thermostat to GMT rather than local time. The Admin console has the correct local time. All of the scheduled events work properly. When the set time command is run, the thermostat is set to the correct time in GMT. This command worked for years on the old hardware. I do not use thermostat programing so it's not a problem. It is weird. though.
sounds like a bug that I haven't seen anyone report yet, like you most people here probably don't use thermostat programing because they have an ISY.  Should probably open a support ticket: support@universal-devices.com to make sure the bug is tracked.
  • 2 months later...
from time to time mine lose time on the 994 and i have to set time manually at different houses.  i have not checked on the polisy one lately.  i think it was more of the thermostat version, i have not noticed it recently.
have replaced a few over the years.
      378.6k
