No Config Fields to Populate
Hey all, i just installed this server on my polisy and i went to enter in all of my config information but the only fields were the short poll and long poll. How or where do i enter clientID, client secret and other config info??
Yep that seemed to do it! Thanks for the fix.
You answered this question awhile back (so i apologize for reasking), but the PRECIP value, i recall, isn't the actual precipitation accumulation for the day correct? Isn't it only the accumulation for the last hour?
Can you remind me the best way to get precipitation accumulation for the day? I have an ambient weather station that publishes its data to PWS Weather.
  • sys.node.[address].PRECIP (current precipitation accumulation)
Thanks again! Is there any more documentation around the Plant Type variable? I've always left it at the default and tweaked some other calculations till i get a solution i'm happy with.
Plant type is a variable used in the evapotranspiration (ETo) calculation.  There are different values for different types of vegetation.   0.26 is a common value for residential environments.  You'd have to lookup details on the calculation for more information.
