UD Mobile Notifications support?
Solved by Jimbo.Automates
OK it is working now... seems just had to leave it sit for a while.
I tested using Send Sys Short With Params using the parameters. I did not find that the Sound setting works for different sounds, but I had same issue with Pushover - maybe because I am using an Apple Watch?
Every Custom Emails/Notifications Customizations worked just like with Pushover.
These contain the Data in the Subject... here is example of one I used named Alarm Disamed Brian as above:
Alarm Disarmed
${sys.date} ${sys.time12}
Alarm Auto Disarmed
Door Entry: Brian
Here is screenshot showing exactly where it goes. It uses the Subject and nothing required in the Body. Note that you can also use the same Customization for email and even put more details in the Body which the notifications server simply ignores.
Edited by brians
  • 3 months later...
Having just set up UD Mobile native Notifications, I wanted to compare its functionality to using the Notification Node Server. However, I was unable to find directions in the instructions for setting this up.
Looking at the screen captures above, I don't have Notification Controller - Service ISYPortal UD. How is this set up?
https://github.com/UniversalDevicesInc-PG3/udi-poly-notification/blob/master/README.md#isy-portal
