Replaced a switch - programmed stopped working
I get this message in the program in the if statement.
I can't remember what I was looking at.  I think it was the status of the switch.
How can I tell what condition this was looking for?
Warning:  Unrecognized Condition (program may not run)
<status OP="IS" NODE="7 E5 1C 3" ID="ST">
    <val UOM="51" PREC="0">0</val>
</status>
looks like it was the status of a switch.  What is the program supposed to do.  Copy and paste the full program.  Right click the program name, the last option on the context menu is Copy to Clipboard, paste it into a forum message.
What the program did was when there was motion from the Ring, it would turn the front lights on for a couple minutes and toggle them off, but if the light was already on, it would stay on.
I used a couple programs to get this to work.  I'll post later tonight the actual programs.
I think I was directly controlling the switch to turn it on, but looking at the scene to see if it was already on.
How was the Ring information being passed to the ISY? The Ring cloud node server has been offline a long time so hasn’t been working. If using other methods then please post whole program as @MrBill suggested in first reply.
I did get this working.  Documenting what I have in case it helps anyone.
I'm using a routine in alexa to run entrymonvar program on ISY
Anytime the front door sees motion, alexa turns on the entrymonvar program
When motion is not seen for 10 minutes  alexa turns off the entrymonvar program
The entrymonvar program
entrymonitorvar - [ID 0010][Parent 0001]
        $motion  = 1
        Run Program 'axexamontionprog' (If)
        $motion  = 0
        Run Program 'motionmain' (If)
The axexamontionprog
axexamontionprog - [ID 0011][Parent 0001]
        From    Sunset
        To      Sunrise (next day)
    And $motion is 1
The motionmain program
motionmain - [ID 0013][Parent 0001]
        $entry_var is 1
     Or $motion is 1
        Set 'Front Entry' On
        Set 'Front Entry' Off
And finally the entryvar program
entryvar - [ID 0012][Parent 0001]
        'breakkey_a' Status is Off    #####(this was the one that was missing)########
        $entry_var  = 0
        $entry_var  = 1
This seems like overkill to use 4 programs and 2 variables but it does work.
The idea here was that the light would stay on if it was turned on by a scene.  If motion turned it on, then only the switch was turned on, so I could use the status of another switch in the scene to see that it was motion that turned in on or the switch directly.
Edited by PAstrachan
