February 3, 201016 yr Is there a way to get my KPL LED for Non-Toggle OFF mode to be unlit? Currently, regardless of if I try non-toggle ON or non-toggle OFF the LED remains lit. Thanks
February 4, 201016 yr Out of curiosity, are the other keys lit while in the off condition? My experience is that non-toggle off buttons will be dim, based on the setting of the entire keypad. I recall, too, that earlier models of keypads have differing capabilities with regards to backlighting and ISY access to this feature.
February 4, 201016 yr Hi okane, I must resonate with what oberkc suggested: they cannot be completely unlit unless you completely turn off the back light for all of them. With kind regards, Michel
February 5, 201016 yr I should clarify, the key is not lighted to the background brightness level, but rather the full bright ON level. They other keys are at the background brightness. Thanks
February 5, 201016 yr I would double check to confirm it is not set to non-toggle on, otherwise, I have no explanation within the realm of a functioning device. Though I have never tried it, is it possible that this keypad is part of a scene that has turned it on, or in response to a programmed command? I am not even sure that it is possible to turn on a keypad set into the non-toggle off mode, but it may be worth checking.
