PG3 ELK Node server 3.4.9
I updated to elk Node server 3.4.9   The elk Node server status in PG3 shows disconnected. When I try and access the log file using the PG3 GUI, I get a 404 not found error. I have tried to delete and recreate the elk Node server. I have rebooted my polisy box. I have tried all these things repeatedly. Now all of my node servers (not just elk) are showing disconnected status in the PG3 GUI.  I am running PG3 3.0.63, and IoP 5.4.4
I have made sure there were no pending updates on my polisy box as shown below.  Something is seriously wrong here but I don't know how to proceed:
[admin@polisy ~]$ sudo pkg update
Password:
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
[admin@polisy ~]$ sudo pkg upgrade
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
[admin@polisy ~]$ sudo service udx status
udx is running as pid 1148.
[admin@polisy ~]$ sudo service isy status
isy is running as pid 1216.
[admin@polisy ~]$ sudo service pg3 status
pg3 is running as pid 794.
You should not be using pkg upgrade, only use Upgrade Packages in the admin console. Send a support ticket using the URL Michel has in his signature.
I have opened a ticket. I'll post back here when I am able to make progress.
I pressed the "Upgrade Packages" button in the AC, and waited until it appeared changes were complete. (I never got 4 beeps, but waited until only the far left LED on the polisy box was illuminated. ) I then restarted PG3, and many things seem to be now working correctly once again, including Elk Node server 3.4.9
Just thought I would pass this error along. Doesn't seem to affect the operation.
Thanks Gary
2022-08-25 08:37:33,515 Thread-2163 udi_interface DEBUG Controller:shortPoll: done 2022-08-25 08:37:36,713 ELK-21607 udi_interface INFO Controller:callback: ELK Controller: cs={'real_time_clock': '3537085250822110'} 2022-08-25 08:37:36,714 ELK-21607 udi_interface INFO Controller:callback: real_time_clock=3537085250822110 2022-08-25 08:37:38,524 ELK-21607 udi_interface ERROR Controller:timeout: ELK Controller: Timeout sending message ZV!!! 2022-08-25 08:37:38,526 ELK-21607 udi_interface.node DEBUG node:setDriver: controller:ELK Controller Reporting set ERR to 1 to Polyglot 2022-08-25 08:37:38,527 ELK-21607 udi_interface.node DEBUG node:reportDriver: Updating value to 1 2022-08-25 08:37:38,527 ELK-21607 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 'controller', 'driver': 'ERR', 'value': '1', 'uom': 56}]} 2022-08-25 08:37:38,529 ELK-21607 udi_interface.custom DEBUG custom:__setitem__: CUSTOM: ns_error = ERROR: 08/25/2022 08:37:38 See log for: ELK Controller: Timeout sending message ZV!!! ...saving 2022-08-25 08:37:38,530 ELK-21607 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2022-08-25 08:37:38,531 ELK-21607 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'key': 'notices', 'value': {'ns_error': 'ERROR: 08/25/2022 08:37:38 See log for: ELK Controller: Timeout sending message ZV!!!'}}]} 2022-08-25 08:37:38,533 ELK-21607 udi_interface DEBUG Controller:set_st: ELK Controller: elk_st=1 st=6 2022-08-25 08:37:38,534 ELK-21607 udi_interface.node DEBUG node:setDriver: controller:ELK Controller Reporting set GV1 to 6 to Polyglot 2022-08-25 08:37:38,535 ELK-21607 udi_interface.node DEBUG node:reportDriver: Updating value to 6 2022-08-25 08:37:38,535 ELK-21607 udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'address': 'controller', 'driver': 'GV1', 'value': '6', 'uom': 25}]} 2022-08-25 08:37:38,685 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message notices 2022-08-25 08:37:38,687 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING notices 2022-08-25 08:37:38,688 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {'ns_error': 'ERROR: 08/25/2022 08:37:38 See log for: ELK Controller: Timeout sending message ZV!!!'} 2022-08-25 08:37:38,689 Command udi_interface.custom DEBUG custom:load: CUSTOM: -- checking ns_error / ERROR: 08/25/2022 08:37:38 See log for: ELK Controller: Timeout sending message ZV!!! 2022-08-25 08:37:38,728 MQTT udi_interface.interface INFO interface:_message: Successfully set controller :: ERR to 1 UOM 56 2022-08-25 08:37:38,730 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2022-08-25 08:37:38,810 MQTT udi_interface.interface INFO interface:_message: Successfully set controller :: GV1 to 6 UOM 25 2022-08-25 08:37:40,203 ELK-21607 udi_interface INFO Zone:callback: zone_8:Outside Temp: changeset={'voltage': 0.7} 2022-08-25 08:37:40,204 ELK-21607 udi_interface DEBUG Zone:_set_voltage: zone_8:Outside Temp: val=0.7 2022-08-25 08:37:40,204 ELK-21607 udi_interface DEBUG BaseNode:set_driver: zone_8:Outside Temp: CV,0.7 default=None force=False,report=True
