Unable to connect to Polisy (PG3 or IoP)
I use and enjoy my ISY and Polisy every day.
A recent update seems to have broken my Polisy.  I cannot find the admin console or login via SSH. (My Polisy is still a test mule, still with default user/password admin, My ISY is production.  The polisy was already running fairly recent updates)
A couple of days ago I used the Admin Console to Upgrade Packages on my working Polisy. Without any real feedback, the Polisy went off and did something.  My polisy is in the basement so I can't hear beeps. (I really really really miss sudo pkg update/upgrade, with all that verbose logging information.)
Today I tried to logon with ISY finder/java.   My ISY showed up, but my Polisy was missing.  I reserve an ip address for my Polisy and tried to SSH and did get connected to the standard login terminal prompt.  However, login as: admin after hitting "enter"  I get "Remote side unexpectedly closed network connection."
Several cold reboots, single solid green light, single beep.   Still no Polisy admin console, no SSH.  Polisy does show up as acquiring IP in router. SSH connects but closes connection.
Suggestions?
Edited by whywork
Solved by Michel Kohanim
I have the same issue.  I wish we had a better workflow for upgrades.
Opened up Polisy and connected to serial console port ala mwester (Thank you!)  For future information serial port is 115200 8n1
Watched Polisy Boot - got a few error messages and then a login prompt.  Any keyboard input then generates repeat
SD_1.0"
2022-08-17T10:50:51.160880-04:00 polisy su 8607 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:50:51.161517-04:00 polisy su 8607 - - pam_start: System error
2022-08-17T10:50:51.440353-04:00 polisy su 8629 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:50:51.441921-04:00 polisy su 8629 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:50:51.442541-04:00 polisy su 8629 - - pam_start: System error
2022-08-17T10:50:56.721626-04:00 polisy su 8648 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:50:56.723202-04:00 polisy su 8648 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:50:56.723830-04:00 polisy su 8648 - - pam_start: System error
2022-08-17T10:50:57.001788-04:00 polisy su 8670 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:50:57.003369-04:00 polisy su 8670 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:50:57.003970-04:00 polisy su 8670 - - pam_start: System error
2022-08-17T10:51:02.285111-04:00 polisy su 8689 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:51:02.286681-04:00 polisy su 8689 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:51:02.287322-04:00 polisy su 8689 - - pam_start: System error
2022-08-17T10:51:02.566529-04:00 polisy su 8711 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:51:02.568102-04:00 polisy su 8711 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:51:02.568713-04:00 polisy su 8711 - - pam_start: System error
Tried Factory Reset hardware button.  No change.
Polisy still borked.  (this after using recommended admin console upgrade path)
Tried to open ticket - More frustration - told to login via portal, logged in and can see my devices, tried to open ticket, told to logon again, and again.  Tried with Chrome incognito, and pihole disabled.  Still cant get to place to create ticket.
Frustrated!
Hi,
As usual, Michel, thanks for the quick reply.
Polisy Pro.
No joy.  One button press to upgrade Polisy packages, gives immediate one boop and six beeps. ttyul
console still with error messages. Waited 10 minutes. Never received 4 beeps + 1.  No change.  Cold boot. No change. Polisy completes boot, error message about unable to start iSY, ttyul shows logon, then repeating error messages preventing logon.
Ticket generation
I think my universal devices "account" is broken too.
 https://www.universal-devices.com/my-tickets  I go to create ticket, tells me to login via isy portal. Complete logon using my https://my.isy.io/ credentials.   Then I get RE prompted by MyTickets to logon, click button and just refreshes saying logon.   When logged on to https://www.universal-devices.com/my-account/ as directed by https://www.universal-devices.com/my-tickets  There are TWO Polisy Pro's registered to me.  NEITHER has the UUID of my Polisy but the numbers listed seem to be the mac address of the ethernet and wifi adapters.  Clicking on either device in https://www.universal-devices.com/my-account/  Says Not a valid serial number.
I can logon to https://my.isy.io/ and see a valid UUID for my Polisy.
But I cannot create ticket on  https://www.universal-devices.com/my-tickets with same credentials.   Tried Chrome, Firefox, Edge and in private mode and turned off Pihole.
I use and enjoy my ISY and Polisy.  UDI support is excellent.
I still seem to have a broken Polisy Pro.
Here is what I see
Universal Devices Polisy
coreboot build 20192108
BIOS version v1.0.0
4080 MB ECC DRAM
         ________  ________  ___       ___  ________       ___    ___
        |\   __  \|\   __  \|\  \     |\  \|\   ____\     |\  \  /  /|
        \ \  \_\  \ \  \|\  \ \  \    \ \  \ \  \___|_    \ \  \/  / /
         \ \   ____\ \  \ \  \ \  \    \ \  \ \_____  \    \ \    / /
          \ \  \___|\ \  \_\  \ \  \____\ \  \|____|\  \    \/  /  /
           \ \__\    \ \_______\ \_______\ \__\____\_\  \  _/  / /
            \|__|     \|_______|\|_______|\|__|\_________\|___/ /
                                              \|_________\|___|/
Press F9 to enter Boot Manager Menu
                                              \|_________\|___|/
>> FreeBSD EFI boot block
   Loader path: /boot/loader.efi
   Initializing modules: ZFS UFS
   Load Path: \EFI\BOOT\BOOTX64.EFI
   Load Device: PciRoot(0x0)/Pci(0x11,0x0)/Sata(0x0,0xFFFF,0x0)/HD(2,GPT,57AC038
8-220D-11EA-B769-598ECAF57D7D,0x428,0x640)
   BootCurrent: 0001
   BootOrder: 0000 0001[*]
   Probing 5 block devices......*. done
    ZFS found the following pools: zudi
    UFS found no partitions
Consoles: EFI console
    Reading loader env vars from /efi/freebsd/loader.env
Setting currdev to disk0p3:
FreeBSD/amd64 EFI loader, Revision 1.1
   Command line arguments: loader.efi
   Image base: 0xccc28000
   EFI version: 2.70
   EFI Firmware: EDK II (rev 1.00)
   Console: efi (0x1000)
   Load Path: HD(3,GPT,57AEA4AD-220D-11EA-B769-598ECAF57D7D,0xA68,0x3390000)
   Load Device: PciRoot(0x0)/Pci(0x11,0x0)/Sata(0x0,0xFFFF,0x0)/HD(3,GPT,57AEA4A
   BootCurrent: 0001
   BootInfo Path: PciRoot(0x0)/Pci(0x11,0x0)/Sata(0x0,0xFFFF,0x0)
Ignoring Boot0001: Only one DP found
Trying ZFS pool
Setting currdev to zfs:zudi/ROOT/default:
Loading /boot/defaults/loader.conf
Loading /boot/device.hints
Loading /boot/loader.conf
Loading /boot/loader.conf.local
Loading kernel...
/boot/kernel/kernel text=0x110348 text=0x8ff500 text=0x15b30c data=0x140 data=0x15a8fc+0x2a4704 syms=[0x8+0x11da38+0x8+0x13d790]
Loading configured modules...
/boot/kernel/nctgpio.ko size 0x5328 at 0x145c000
loading required module 'superio'
/boot/kernel/superio.ko size 0x6c80 at 0x1462000
/boot/kernel/zfs.ko size 0x5bb320 at 0x1469000
/boot/entropy size=0x1000
/etc/hostid size=0x25
Hit [Enter] to boot immediately, or any other key for command prompt.
Booting [/boot/kernel/kernel]...
staging 0xc4000000 (not copying) tramp 0xcef5e000 PT4 0xcef55000
Start @ 0xffffffff80310360 ...
EFI framebuffer information:
addr, size     0x0, 0x0
dimensions     0 x 0
stride         0
masks          0x00000000, 0x00000000, 0x00000000, 0x00000000
---<<BOOT>>---
Copyright (c) 1992-2021 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 13.1-RELEASE-p1 releng/13.1-n250155-514a191356c1 POLISY amd64
FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.0-0-gd7b669b3a303)
VT(vga): resolution 640x480
CPU: AMD GX-412TC SOC                                (998.32-MHz K8-class CPU)
  Origin="AuthenticAMD"  Id=0x730f01  Family=0x16  Model=0x30  Stepping=1
  Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x3ed8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C>
  AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
  AMD Features2=0x1d4037ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,Topology,PNXC,DBE,PTSC,PL2I>
  Structured Extended Features=0x8<BMI1>
  XSAVE Features=0x1<XSAVEOPT>
  SVM: NP,NRIP,AFlush,DAssist,NAsids=8
  TSC: P-state invariant, performance statistics
real memory  = 4294967296 (4096 MB)
avail memory = 4098949120 (3909 MB)
Event timer "LAPIC" quality 100
ACPI APIC Table: <COREv4 COREBOOT>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
random: unblocking device.
ioapic1: MADT APIC ID 5 != hw id 0
ioapic0 <Version 2.1> irqs 0-23
ioapic1 <Version 2.1> irqs 24-55
Launching APs: 2 1 3
random: entropy device external interface
WARNING: Device "spkr" is Giant locked and may be deleted before FreeBSD 14.0.
vtvga0: <VT VGA driver>
efirtc0: <EFI Realtime Clock>
efirtc0: registered as a time-of-day clock, resolution 1.000000s
smbios0: <System Management BIOS> at iomem 0xcf7c9000-0xcf7c901e
smbios0: Version: 3.3, BCD Revision: 3.3
aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS>
acpi0: <COREv4 COREBOOT>
acpi0: Power Button (fixed)
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x818-0x81b on acpi0
apei0: <ACPI Platform Error Interface> on acpi0
cpu0: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pcib0: could not evaluate _ADR - AE_NOT_FOUND
pci0: <ACPI PCI bus> on pcib0
pci0: <base peripheral, IOMMU> at device 0.2 (no driver attached)
pcib1: <ACPI PCI-PCI bridge> at device 2.1 on pci0
pci1: <ACPI PCI bus> on pcib1
ath0: <Atheros AR946x/AR948x> mem 0xf7900000-0xf797ffff at device 0.0 on pci1
ar9300_flash_map: unimplemented for now
Restoring Cal data from DRAM
Restoring Cal data from EEPROM
Restoring Cal data from Flash
Restoring Cal data from OTP
ar9300_hw_attach: ar9300_eeprom_attach returned 0
ath0: [HT] enabling HT modes
ath0: [HT] enabling short-GI in 20MHz mode
ath0: [HT] 1 stream STBC receive enabled
ath0: [HT] 1 stream STBC transmit enabled
ath0: [HT] LDPC transmit/receive enabled
ath0: [HT] 2 RX streams; 2 TX streams
ath0: AR9460 mac 640.2 RF5110 phy 1158.6
ath0: 2GHz radio: 0x0000; 5GHz radio: 0x0000
pcib2: <ACPI PCI-PCI bridge> at device 2.2 on pci0
pcib2: failed to allocate initial I/O port window: 0x1000-0x1fff
pci2: <ACPI PCI bus> on pcib2
igb0: <Intel(R) I210 Flashless (Copper)> port 0x2000-0x201f mem 0xf7a00000-0xf7a1ffff,0xf7a20000-0xf7a23fff at device 0.0 on pci2
igb0: NVM V0.6 imgtype5
igb0: Using 1024 TX descriptors and 1024 RX descriptors
igb0: Using 4 RX queues 4 TX queues
igb0: Using MSI-X interrupts with 5 vectors
igb0: Ethernet address: 00:0d:b9:53:36:9c
igb0: netmap queues/slots: TX 4/1024, RX 4/1024
pcib3: <ACPI PCI-PCI bridge> at device 2.3 on pci0
pcib3: failed to allocate initial I/O port window: 0x2000-0x2fff
pci3: <ACPI PCI bus> on pcib3
igb1: <Intel(R) I210 Flashless (Copper)> port 0x3000-0x301f mem 0xf7b00000-0xf7b1ffff,0xf7b20000-0xf7b23fff at device 0.0 on pci3
igb1: NVM V0.6 imgtype5
igb1: Using 1024 TX descriptors and 1024 RX descriptors
igb1: Using 4 RX queues 4 TX queues
igb1: Using MSI-X interrupts with 5 vectors
igb1: Ethernet address: 00:0d:b9:53:36:9d
igb1: netmap queues/slots: TX 4/1024, RX 4/1024
pcib4: <ACPI PCI-PCI bridge> at device 2.4 on pci0
pcib4: failed to allocate initial I/O port window: 0x3000-0x3fff
pci4: <ACPI PCI bus> on pcib4
igb2: <Intel(R) I210 Flashless (Copper)> port 0x5000-0x501f mem 0xf7c00000-0xf7c1ffff,0xf7c20000-0xf7c23fff at device 0.0 on pci4
igb2: NVM V0.6 imgtype5
igb2: Using 1024 TX descriptors and 1024 RX descriptors
igb2: Using 4 RX queues 4 TX queues
igb2: Using MSI-X interrupts with 5 vectors
igb2: Ethernet address: 00:0d:b9:53:36:9e
igb2: netmap queues/slots: TX 4/1024, RX 4/1024
pci0: <encrypt/decrypt> at device 8.0 (no driver attached)
xhci0: <AMD FCH USB 3.0 controller> mem 0xf7fa2000-0xf7fa3fff at device 16.0 on pci0
xhci0: 32 bytes context size, 64-bit DMA
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
ahci0: <AMD Hudson-2 AHCI SATA controller> port 0x4010-0x4017,0x4020-0x4023,0x4018-0x401f,0x4024-0x4027,0x4000-0x400f mem 0xf7fa5000-0xf7fa53ff at device 17.0 on pci0
ahci0: AHCI v1.30 with 2 6Gbps ports, Port Multiplier supported with FBS
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ehci0: <AMD FCH USB 2.0 controller> mem 0xf7fa6000-0xf7fa60ff at device 19.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
usbus1: 480Mbps High Speed USB v2.0
intsmb0: <AMD FCH SMBus Controller> at device 20.0 on pci0
smbus0: <System Management Bus> on intsmb0
smb0: <SMBus generic I/O> on smbus0
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
sdhci_pci0: <Generic SD HCI> mem 0xf7fa7000-0xf7fa70ff at device 20.7 on pci0
sdhci_pci0: 1 slot(s) allocated
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb5
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart1: console (115200,n,8,1)
tpm0: <Trusted Platform Module> port 0xc31-0xc32 iomem 0xfed40000-0xfed44fff on acpi0
tpm: device 0x001a15d1 rev 0x10
WARNING: Device "tpm" is Giant locked and may be deleted before FreeBSD 14.0.
superio0: <Nuvoton NCT5104D/NCT6102D/NCT6106D (rev. B+)> at port 0x2e-0x2f on isa0
gpio0: <Nuvoton GPIO controller> at GPIO ldn 0x07 on superio0
gpiobus0: <GPIO bus> on gpio0
gpioc0: <GPIO controller> on gpio0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
Timecounter "TSC" frequency 998127822 Hz quality 1000
Timecounters tick every 1.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Trying to mount root from zfs:zudi/ROOT/default []...
ugen1.1: <AMD EHCI root HUB> at usbus1
ugen0.1: <AMD XHCI root HUB> at usbus0
uhub0 on usbus1
uhub0: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub1 on usbus0
uhub1: <AMD XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
uhub1: 4 ports with 4 removable, self powered
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <SATA SSD SBFM61.2> ACS-4 ATA SATA 3.x device
ada0: Serial Number A45A0797068601319278
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 30533MB (62533296 512 byte sectors)
Root mount waiting for: usbus1
uhub0: 2 ports with 2 removable, self powered
ugen1.2: <vendor 0x0438 product 0x7900> at usbus1
uhub2 on uhub0
uhub2: <vendor 0x0438 product 0x7900, class 9/0, rev 2.00/0.18, addr 2> on usbus1
uhub2: 4 ports with 4 removable, self powered
ugen1.3: <vendor 0x0cf3 product 0xe003> at usbus1
Dual Console: Serial Primary, Video Secondary
Setting hostuuid: 4ee43bd5-9195-11e7-9e62-000db953369c.
Setting hostid: 0x7067e1fe.
no pools available to import
Starting file system checks:
Mounting local filesystems:.
ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib /usr/local/lib/compat/pkg /usr/local/lib/compat/pkg /usr/local/lib/perl5/5.32/mach/CORE
32-bit compatibility ldconfig path:
Setting hostname: polisy.
Additional TCP/IP options: ipv4-mapped-ipv6=YES.
Setting up harvesting: [UMA],[FS_ATIME],SWI,INTERRUPT,NET_NG,[NET_ETHER],NET_TUN,MOUSE,KEYBOARD,ATTACH,CACHED
Feeding entropy: .
Loading kernel modules:
apuled0: <APU2> at iomem 0xfed81610-0xfed8161b,0xfed81664-0xfed81667 on isa0
resetsw0: <UDXRSW-2> at iomem 0xfed81664-0xfed81667 on isa0
wlan0: Ethernet address: 90:48:9a:33:8d:49
Created wlan(4) interfaces: wlan0.
lo0: link state changed to UP
Starting wpa_supplicant.
wlan0: link state changed to UP
Starting Network: lo0 igb0 wlan0.
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
        inet 127.0.0.1 netmask 0xff000000
        groups: lo
        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
igb0: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=4e527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
        ether 00:0d:b9:53:36:9c
        inet6 fe80::20d:b9ff:fe53:369c%igb0 prefixlen 64 scopeid 0x1
        media: Ethernet autoselect
        status: no carrier
        nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
wlan0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 90:48:9a:33:8d:49
        inet6 fe80::9248:9aff:fe33:8d49%wlan0 prefixlen 64 scopeid 0x7
        groups: wlan
        ssid Galefront channel 1 (2412 MHz 11g ht/20) bssid b4:fb:e4:d2:94:56
        regdomain FCC country US indoor ecm authmode WPA2/802.11i privacy ON
        deftxkey UNDEF AES-CCM 2:128-bit txpower 30 bmiss 7 scanvalid 60
        protmode CTS ampdulimit 64k ampdudensity 4 shortgi -uapsd wme burst
        roaming MANUAL
        parent interface: ath0
        media: IEEE 802.11 Wireless Ethernet MCS mode 11ng
        status: associated
Starting rtsold.
Starting devd.
Autoloading module: ng_ubt
ubt0 on uhub2
ubt0: <vendor 0x0cf3 product 0xe003, class 224/1, rev 1.10/0.01, addr 3> on usbus1
Starting dhclient.
WARNING: attempt to domain_add(bluetooth) after domainfinalize()
WARNING: attempt to domain_add(netgraph) after domainfinalize()
add host 127.0.0.1: gateway lo0 fib 0: route already in table
add host ::1: gateway lo0 fib 0: route already in table
add net fe80::: gateway ::1
add net ff02::: gateway ::1
add net ::ffff:0.0.0.0: gateway ::1
add net ::0.0.0.0: gateway ::1
Starting pg3.
2022-08-17T10:11:33.553860-04:00 polisy su 846 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:33.555840-04:00 polisy su 846 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:33.556464-04:00 polisy su 846 - - pam_start: System error
su: pam_start: System error
/etc/rc: WARNING: failed to start pg3
Starting mongod.
2022-08-17T10:11:33.591735-04:00 polisy su 854 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:33.592878-04:00 polisy su 854 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:33.593267-04:00 polisy su 854 - - pam_start: System error
/etc/rc: WARNING: failed to start mongod
Allowing polyglot to listen on port 443...
net.inet.ip.portrange.reservedhigh: 1023 -> 442
Starting polyglot.
2022-08-17T10:11:33.691137-04:00 polisy su 870 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:33.692199-04:00 polisy su 870 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:33.692605-04:00 polisy su 870 - - pam_start: System error
/etc/rc: WARNING: failed to start polyglot
/etc/rc: WARNING: /etc/newsyslog.conf is not readable.
Clearing /tmp.
Updating motd:.
Updating /var/run/os-release done.
/etc/rc: WARNING: run_rc_command: cannot run /usr/sbin/syslogd
Starting powerdxx.
Starting hcsecd.
Mounting late filesystems:.
Security policy loaded: MAC/ntpd (mac_ntpd)
Starting ntpd.
2022-08-17T10:11:34.261841-04:00 polisy su 1073 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:34.262890-04:00 polisy su 1073 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:34.263327-04:00 polisy su 1073 - - pam_start: System error
/etc/rc: WARNING: failed to start ntpd
Starting sdpd.
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: making sure all prereqs are installed ...
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: pkg already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: ca_root_nss already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: dual-dhclient already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: bash already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: mongodb36 already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: p5-IO-Socket-SSL already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: git already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: sudo already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: polyglot already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: mosquitto already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: libwebsockets already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: powerdxx already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: e2fsprogs-libuuid already installed
Wed Aug 17 10:11:34 EDT 2022|/etc/rc: c-ares already installed
Wed Aug 17 10:11:35 EDT 2022|/etc/rc: rapidjson already installed
Wed Aug 17 10:11:35 EDT 2022|/etc/rc: mongo-c-driver already installed
Wed Aug 17 10:11:35 EDT 2022|/etc/rc: npm already installed
Wed Aug 17 10:11:35 EDT 2022|/etc/rc: isy already installed
Wed Aug 17 10:11:35 EDT 2022|/etc/rc: tpm2-tools already installed
Wed Aug 17 10:11:35 EDT 2022|/etc/rc: dmidecode already installed
Wed Aug 17 10:11:35 EDT 2022|/etc/rc: pg3 already installed
Starting udx.
Checking to see whether or not we need to migrate from 994 ...
Setting permissions for ISY directories/files
Setting permissions for LEDs
checking udx version = 3120 for possible upgrade
udx is upto date
udx is running as pid 1199.
you can disable uftdi driver by adding isy_load_uftdi=NO in /etc/rc.conf
Starting isy.
2022-08-17T10:11:35.476580-04:00 polisy su 1265 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:35.477995-04:00 polisy su 1265 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:35.478605-04:00 polisy su 1265 - - pam_start: System error
/etc/rc: WARNING: failed to start isy
Starting cron.
Performing sanity check on sshd configuration.
Starting sshd.
Starting background file system checks in 60 seconds.
FreeBSD/amd64 (polisy) (ttyu1)
login: 2022-08-17T10:11:41.976295-04:00 polisy su 2052 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:41.977312-04:00 polisy su 2052 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:41.977724-04:00 polisy su 2052 - - pam_start: System error
2022-08-17T10:11:42.162701-04:00 polisy su 2074 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:42.163738-04:00 polisy su 2074 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:42.164121-04:00 polisy su 2074 - - pam_start: System error
2022-08-17T10:11:47.384717-04:00 polisy su 2093 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:47.386279-04:00 polisy su 2093 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:47.386935-04:00 polisy su 2093 - - pam_start: System error
2022-08-17T10:11:47.667287-04:00 polisy su 2115 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:47.668856-04:00 polisy su 2115 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:47.669472-04:00 polisy su 2115 - - pam_start: System error
2022-08-17T10:11:52.929073-04:00 polisy su 2134 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:52.930650-04:00 polisy su 2134 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:52.931288-04:00 polisy su 2134 - - pam_start: System error
2022-08-17T10:11:53.211790-04:00 polisy su 2156 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:53.213362-04:00 polisy su 2156 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:53.213995-04:00 polisy su 2156 - - pam_start: System error
2022-08-17T10:11:58.434372-04:00 polisy su 2175 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:58.435934-04:00 polisy su 2175 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:58.436578-04:00 polisy su 2175 - - pam_start: System error
2022-08-17T10:11:58.716178-04:00 polisy su 2197 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:11:58.717760-04:00 polisy su 2197 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:11:58.718376-04:00 polisy su 2197 - - pam_start: System error
wlan0: link state changed to DOWN
2022-08-17T10:12:04.044699-04:00 polisy su 2343 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:04.046351-04:00 polisy su 2343 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:04.047011-04:00 polisy su 2343 - - pam_start: System error
2022-08-17T10:12:04.330348-04:00 polisy su 2382 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:04.331928-04:00 polisy su 2382 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:04.332552-04:00 polisy su 2382 - - pam_start: System error
2022-08-17T10:12:09.599811-04:00 polisy su 2401 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:09.601376-04:00 polisy su 2401 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:09.602023-04:00 polisy su 2401 - - pam_start: System error
2022-08-17T10:12:09.881682-04:00 polisy su 2423 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:09.883270-04:00 polisy su 2423 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:09.883871-04:00 polisy su 2423 - - pam_start: System error
2022-08-17T10:12:15.114927-04:00 polisy su 2442 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:15.116526-04:00 polisy su 2442 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:15.117194-04:00 polisy su 2442 - - pam_start: System error
2022-08-17T10:12:15.396940-04:00 polisy su 2464 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:15.398521-04:00 polisy su 2464 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:15.399142-04:00 polisy su 2464 - - pam_start: System error
2022-08-17T10:12:20.632205-04:00 polisy su 2483 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:20.633763-04:00 polisy su 2483 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:20.634420-04:00 polisy su 2483 - - pam_start: System error
2022-08-17T10:12:20.914764-04:00 polisy su 2505 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:20.916328-04:00 polisy su 2505 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:20.916917-04:00 polisy su 2505 - - pam_start: System error
2022-08-17T10:12:26.142940-04:00 polisy su 2524 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:26.144540-04:00 polisy su 2524 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:26.145192-04:00 polisy su 2524 - - pam_start: System error
2022-08-17T10:12:26.424866-04:00 polisy su 2546 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:26.426468-04:00 polisy su 2546 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:26.427076-04:00 polisy su 2546 - - pam_start: System error
2022-08-17T10:12:31.646966-04:00 polisy su 2565 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:31.648542-04:00 polisy su 2565 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:31.649201-04:00 polisy su 2565 - - pam_start: System error
2022-08-17T10:12:31.929096-04:00 polisy su 2587 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:31.930668-04:00 polisy su 2587 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:31.931289-04:00 polisy su 2587 - - pam_start: System error
2022-08-17T10:12:37.149166-04:00 polisy su 2606 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:37.150773-04:00 polisy su 2606 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:37.151426-04:00 polisy su 2606 - - pam_start: System error
2022-08-17T10:12:37.431308-04:00 polisy su 2628 - - in try_dlopen(): /usr/lib/pam_unix.so.6: /usr/lib/libypclnt.so.4: Undefined symbol "xdr_domainname@FBSD_1.0"
2022-08-17T10:12:37.432880-04:00 polisy su 2628 - - in openpam_load_module(): no pam_unix.so found
2022-08-17T10:12:37.433494-04:00 polisy su 2628 - - pam_start: System error
There appears to be an issue with the ticket endpoint. Try the following URL until we correct the issue.
https://www.universal-devices.com/my-tickets/?wpsc-section=ticket-list
Also, try waiting more than 10 minutes before interfering with the upgrade process.  I usually do upgrades before lunch and sometimes hear the beep sequence after 15 minutes or more.
My Polisy's in an inconvenient place for beeps and lights, and even if I was there I can't physically hear the beeps anyway.  I use http://IP.ADDR.of.Polisy:8080/WEB/udajax.htm to determine when the upgrade is complete... if that page loads and requests credentials then IoP is back and I can open the admin console.  I wish we could just get a simple status page on some arcane port that could be opened in a web browser, nothing fancy just text.
My Polisy is back up and running.
Thanks to UDI support.
Instructions to, "Please click on the button on the front only once and wait for 4 + 1 beeps, then reboot."
Worked.
Back up and running.
Thank you for your efforts
